Broadband speeds keep dropping out at irregular times
- Full Fibre
- Re: Broadband speeds keep dropping out at irregula...
27-04-2026 6:59 PM
For the past 5 or 6 weeks our broadband has become unreliable. I have tried all the usual
Restart router
Change Channel
Plug into router
etc etc
There is no specific times and it just happens at random. All online TV channels go "blocky" and the speeds drop to crazy low levels and we have had many similar .. the 'outages' can last anything from 10 minutes to 3/4 hour
I have asked my husband to do speed tests as he is the one that works mainly from home using the home broadband
He is often sat right next to the router.
I have had several periods of time where I've also noticed very slow speeds.
For info I am supposed to be on full fibre 300
Please can someone investigate this for me.
There is no point in doing a speed test now as it will show normal levels but here is a reading we took earlier
Hopefully someone can help?
many thanks in advance
Re: Broadband speeds keep dropping out at irregular times
28-04-2026 9:46 AM
@aimless101 Your best option is to use this link to report the fault: Plusnet Report A Problem | Help | Plusnet
28-04-2026 9:52 AM
Moderators Note
This topic has been moved from Broadband to Full Fibre
28-04-2026 10:23 AM
thanks - will do
- Full Fibre
