Battery backup
- Full Fibre
- Re: Battery backup
Battery backup
Thursday
Hi Everyone
We had a 24 hour power cut a couple of weeks ago and that prompted me to look for some sort of backup battery system to allow us to stay on line a little longer - maybe long enough to report the fault and make arrangements for family support. We live in a not spot - so mobile isn't ideal; I'd have to go out with my phone to find a signal!
Anyway, I found a Jackery 300D portable power station on Amazon for just about £113, which apparently can store almost 300W/h for a reasonable amount of time. It has a few USB-C outputs so we can use it to charge phones if we need to, and a car-type 12VDC output as well. The plan was to buy a few cables to connect it all up, preferably in a way so that if we get a power cut, I can just turn the power station and plug the ONT and router to it to restore wifi and internet (assuming there will be power at the outreach cabinet, a couple of miles away).
And the cabling is where I am struggling.
I have a car power plug to go into the cigarette light port on the power station, and that goes to a 5.5 × 2.1 mm barrel connector for the broadband.modem (an old Archer VR600). The idea was to have a 5.5 × 2.1 mm MFF Y-cable with a male connector to plug into the modem, and then use one of the female ends to attach the power station, and use the other female end to plug in the normal power supply. When the power goes, I would just need to turn on the power station and then just plug in the connector to the power station.
Problem is the only Y cables I have been able to find are marked as 5.5 x 2.1mm, but they are actually 5.5 x 2.5 or something. Whatever size they are, a normal 5.5 x 2.1 wont fit - the inner prong is to big to allow the plug to fit in.
Then, for the ONT, this is an Openreach 12v, which I think is 5.5 x 2.5. The Y-cable I have fits, but I don't have any 5.5 x 2.5 cables to attach to them.
As I am writing this I can see this is going to look really complicated to anyone looking at it from the outside...
So the question:
I can't be the only person to be trying to do this, surely? Does anyone else have a solution to my connection woes? What did you do to overcome the issue? Does anyone know of a source for cables which might solve the problem?
diagram coming
Re: Battery backup
Thursday
I have used a PC UPS unit, which outputs mains.
I use this to power a 4 way strip.
The 4 way strip powers the normal ONT PSU, the router PSU and VOIP phone PSU. The spare sockets powers a desk lamp.
It is always on.
Depending on how you want it, either power everything else on the PC kit off normal mains (and accept the power cuts) or a separate UPS for those which you use as a master switch on the PC kit.
A charged laptop would obviate that lot of course.
Re: Battery backup
yesterday - last edited yesterday
"(assuming there will be power at the outreach cabinet, a couple of miles away)."
Not sure what you mean here. If on full fibre there is no need for any cabinet as, AFAIK, usually all under the ground (unless via telephone pole!) until the head end in a building somewhere. The 'P' in GPON stands for "Passive", apart from the customer's ONT and the OLT (Optical Line Terminal) at the head end, there is usually no electrical/electronic equipment involved within a GPON.
This is unlike VDSL where you would need to depend on backup from a, possibly 'dodgy', battery in the FTTC cabinet to power the out of exchange DSLAM equipment.
Re: Battery backup
yesterday
@shanye wrote:
... for the ONT, this is an Openreach 12v, which I think is 5.5 x 2.5.
I doubt it, most models of Openreach ONT have power connectors that are 5.5 x 2.1
If you tell me the manufacturer and model number on the ONT I can probably find you the Openreach spec for that device.
Re: Battery backup
yesterday
Re: Battery backup
Re: Battery backup
@shanye A Full Fibre connection goes nowhere near the cabs, as you believed in your now edited post.
Re: Battery backup
yesterday
@pvmb - "Not sure what you mean here."
My understanding is that the fibre line goes to a green cabinet a couple of miles away and the equipment within needs power in order to relay the digital signal onto the main network cable. I believe it might have battery power enough to survive a short power loss at the cabinet, but not for 24 hours. I have also read somewhere that sometimes there is no battery back up in the cabinets because the batteries get stolen!
We live in the middle of no-where so the infrastructure is minimal. The fibre gets to us on the same pole the old copper phone lines used to use.
Re: Battery backup
yesterday
See my post above.
Re: Battery backup
yesterday
@ExForce9 I think we have this one. The image I took tonight isn't very helpful, (I'll take another look tomorrow in the day) but the box looks exactly like this one, with the lights at the top and the connectors underneath. According to the net, this is a Nokia-ONT G-010G-R.
Re: Battery backup
yesterday
@jab1 OK - that may well be the case, then. I have had a look and the local exchange is about 3 miles away. I guess they will have reasonable power backup there?
The worry was that I'd mess around getting this sorted out only to find that in a power cut, although we might have limited power here at home, we'd find the fibre still unusable because of loss of power on the other end.
That's very helpful. Thankyou!
Re: Battery backup
yesterday
Re: Battery backup
yesterday
Re: Battery backup
The fibre optic cable does not go to your local Exchange unless it's classed as a Main Exchange. I think they're called Internet Handover Points now (before they were Internet Head Ends).
It's a continuous cable run though at some point it'll be connected to an Aggregator to reduce the number of cables.
OpenReach currently have over 5,000 Exchanges but once everything shakes out in decades to come they'll only have about 1,000 (the Internet Handover Points).
These Main Exchanges will have good quality power backup and would likely not be suffering a power cut at the same time as you.
Re: Battery backup
yesterday
Thanks for that. In some ways that makes things a bit easier. I'm now only looking for a single type of connection.I just need to find a Y cable with MFF which is actually 5.5 x 2.1mm and not anything else. It's really annoying that it looks like all the ones on Ebay and Amazon are marked as 5.5 x 2.1mm, but they really aren't!
I might end up having to make a box with a bunch of female ports wired in parallel to act as a hub for the 12V supply.
