Battery backup
- Full Fibre
- Battery backup
Battery backup
yesterday
Hi Everyone
We had a 24 hour power cut a couple of weeks ago and that prompted me to look for some sort of backup battery system to allow us to stay on line a little longer - maybe long enough to report the fault and make arrangements for family support. We live in a not spot - so mobile isn't ideal; I'd have to go out with my phone to find a signal!
Anyway, I found a Jackery 300D portable power station on Amazon for just about £113, which apparently can store almost 300W/h for a reasonable amount of time. It has a few USB-C outputs so we can use it to charge phones if we need to, and a car-type 12VDC output as well. The plan was to buy a few cables to connect it all up, preferably in a way so that if we get a power cut, I can just turn the power station and plug the ONT and router to it to restore wifi and internet (assuming there will be power at the outreach cabinet, a couple of miles away).
And the cabling is where I am struggling.
I have a car power plug to go into the cigarette light port on the power station, and that goes to a 5.5 × 2.1 mm barrel connector for the broadband.modem (an old Archer VR600). The idea was to have a 5.5 × 2.1 mm MFF Y-cable with a male connector to plug into the modem, and then use one of the female ends to attach the power station, and use the other female end to plug in the normal power supply. When the power goes, I would just need to turn on the power station and then just plug in the connector to the power station.
Problem is the only Y cables I have been able to find are marked as 5.5 x 2.1mm, but they are actually 5.5 x 2.5 or something. Whatever size they are, a normal 5.5 x 2.1 wont fit - the inner prong is to big to allow the plug to fit in.
Then, for the ONT, this is an Openreach 12v, which I think is 5.5 x 2.5. The Y-cable I have fits, but I don't have any 5.5 x 2.5 cables to attach to them.
As I am writing this I can see this is going to look really complicated to anyone looking at it from the outside...
So the question:
I can't be the only person to be trying to do this, surely? Does anyone else have a solution to my connection woes? What did you do to overcome the issue? Does anyone know of a source for cables which might solve the problem?
diagram coming
Re: Battery backup
yesterday
I have used a PC UPS unit, which outputs mains.
I use this to power a 4 way strip.
The 4 way strip powers the normal ONT PSU, the router PSU and VOIP phone PSU. The spare sockets powers a desk lamp.
It is always on.
Depending on how you want it, either power everything else on the PC kit off normal mains (and accept the power cuts) or a separate UPS for those which you use as a master switch on the PC kit.
A charged laptop would obviate that lot of course.
