BT Modem Reliability
- Full Fibre
- Re: BT Modem Reliability
29-03-2011 1:34 PM
I've just had a second faulty BT Modem replaced on my FTTC line. The BT Engineer hinted that they might not be that reliable. Has anyone else needed to have a modem replaced ?
30-03-2011 5:13 PM
pete3D, do you know what the problem was? did the engineer explain?
30-03-2011 6:07 PM
I'm on my 4th modem now and have just lost my Internet connection again (on hold waiting for support) so we'll see what the problem is this time, maybe a 5th modem?
Tim
31-03-2011 11:20 AM
Quote from: _Adam_Walker_ do you know what the problem was?
I didn't get any explanation.
I'd been running on the FTTC trial for some time without any problems, but then started getting drop-outs. I had 120+ drop outs and reconnects in a day on the first modem to go. It couldn't maintain a DSL connection for more than a few minutes. The engineer tested the line, replaced the modem. The problem was fixed. He went away.
The replacement modem lasted a couple of days, I think, before the DSL light went off and never came on again. I tried power off and on a few times over 3 days, checked the cables etc. It didn't reconnect. In fact the box died the morning before the engineer turned up, even the power light went off.
Faced with a dead modem the BT engineer just replaced it.
The 2nd engineer told me that he had been asked by his management to collect any faulty modems for return to Huawei. The modems look pretty cheap and BT can't be paying that much for each unit given how many they must have sourced. Therefore, either BT are just penny pinching or perhaps there is a significant enough number of faulty boxes for them to bother to return them.
I noticed the modems get quite warm. However, mine have been located on a shelf with space around them. I don't think the operating environment is likely to be any worse than a typical home installation.
dick:green Quote fixed.
31-03-2011 3:49 PM
31-03-2011 9:33 PM
The replacement gets hot, but touch wood, is OK. I've also propped it up against the wall so that the vents are ontop and the sides. Before, the old one just sat flat on the desk.
Maybe this way the heat can escape more easily...?
01-04-2011 12:05 PM
http://community.bt.com/t5/BT-Infinity/BT-Infinity-Unreliable-and-poor-service-am-I-the-only-one-wit...
Dave
01-04-2011 12:39 PM
http://www.idnetters.co.uk/forums/index.php?action=printpage;topic=21950.0
is this looking like a pattern ? With Plusnet going live with FTTC and no doubt an increase in users of these modems, it will be interesting to see if there are any other reports.
01-04-2011 4:44 PM
It sounds like Merlin, has the same issue, http://community.plus.net/forum/index.php/topic,94825.0.html I'll be collating these along with any other examples I see.
01-04-2011 4:52 PM
Adam
02-04-2011 7:38 AM
02-04-2011 11:42 AM
Mine is positioned flat but with supports at the short sides so there is 2cm of air below it and open to the air on every other face.
It doesn't get very hot but obviously heats up when there is a lot of netowrk traffic.
I have had it for 6 months.
Dave
02-04-2011 12:10 PM
is the heatsink......
Regards
Roger
05-04-2011 8:39 AM
I hate not having something that I can substitute if there is a problem, especially useful for fault finding. I always kept a spare ADSL router/modem.
05-04-2011 9:29 AM
why is it that these manufacturers continually design stuff like this, wonder how much is due to lead free solder failing under heat...
