Am I eligible?
andrewodonnell
Am I eligible?
So I'd love to be part of the FTTP trial. I currently have plusnet FTTC but I am right on the edge of what's viable - 3km out so I only get about 12mbit/s download and 1mbit/s upload. The underground ducting comes right up the edge of my property and then up the pole outside my garden wall - so my install would be easier than most! Wink
Only thing is, i'm not sue if i'm eligible. BT's own pdf document says my exchange is enabled for FTTP on this document https://www.openreach.co.uk/orpg/home/products/super-fastfibreaccess/downloads/sffa_exchange_lists/a...
Is this what I need to be eligible?
6 REPLIES 6
Aspiring Hero
Fixes: 33
Re: Am I eligible?
What does the DSL Checker say?
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
You need "WBC FTTP" in the left hand column - not FTTP on Demand
Browni
Aspiring Hero
Fixes: 59
Re: Am I eligible?
To be eligible you need to see WBC FTTP in the DSL Checker, NOT FTTPoD.
andrewodonnell
Re: Am I eligible?
I'm afraid the DSL Checker doesn't show WBC FTTP (nor FoD)
Is this the only criteria that's needed for eligibility? Is there a way of keeping track of which cabinets get upgraded to support FTTP (since the exchange does?)
SpendLessTime
Fixes: 86
Re: Am I eligible?
Yes that is the only criteria.
And FTTP isn't linked to the cabinets so that isn't a guide to the product availability either.
You need to find out which local council backed scheme is available in your area and ask them about their plans for FTTP for your area.
andrewodonnell
Re: Am I eligible?
Oh well Sad
Thanks for the help!
Aspiring Hero
Fixes: 33
Re: Am I eligible?
You could try the following to see if there's any plans for your address.
https://www.openreach.co.uk/orpg/home/index.do
Also, look to see if there's a BDUK Superfast project for your area. If there is have a look.
