80/20 FTTC Trial Closed
- Full Fibre
- Re: 80/20 FTTC Trial Open
24-02-2012 10:21 AM
24-02-2012 11:11 AM
I seem to be getting similar results to you - around 50Mbps down although my IP profile is 76Mbps. Let us know if the new router improves it I might have to ask for one
24-02-2012 11:27 AM
24-02-2012 11:29 AM
dick:quote
24-02-2012 11:40 AM
24-02-2012 11:41 AM
24-02-2012 11:52 AM
Quote from: aca02djr I seem to be getting similar results to you - around 50Mbps down although my IP profile is 76Mbps. Let us know if the new router improves it I might have to ask for one
Oh dear. I just unlocked my modem (got a replacement last week so hadn't done it yet), which obviously meant powering it off for a short while, and my line rate is showing as 67737, which must be lower than it was as I had a profile of 72.89M and was getting speed test results of around 70M. I tried to check what my profile is now and am getting "The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider" again, which I got from the time they upgraded the BT speed tester to when I was put on to the 80/20 trial. Speedtest.net now coming in at around 40M and pings around 25ms, far worse than I was getting. Help! I don't think the new router is going to help at all.
Edit: managed to get the profile from http://windows.mouselike.org/be/?DoAction=BrasChecker
The current Downstream BRAS rate is: 65.57 Mbps (down from 72.89)
The current Upstream BRAS rate is: 20 Mbps
24-02-2012 12:47 PM
24-02-2012 1:16 PM
Quote from: walker23
Quote from: paulpicks21 I am sort of scared to connect the new router later seeing as its running so well at the moment.
As long as you leave the modem running it shouldn't affect your connection at all.
Thanks walker, connected the new router and up and running with same speeds as before
24-02-2012 2:16 PM
24-02-2012 2:56 PM
Hope i get picked for the trial
24-02-2012 3:44 PM
Quote from: WWWombat What I did notice is that speeds can be variable, and are now dependent on the machine running the test. For example: my old laptop (2006 vintage) can only sustain 65Mbps on speedtest.net
As the speeds get faster dunno what's on that laptop but WinXP in particular can benefit from the tuning of the TCP receive window.
You can tune stuff using the tweaktest and drtcp tools from here. http://www.dslreports.com/tools
Tom.
24-02-2012 5:29 PM
Plusnet Technology
24-02-2012 6:01 PM
24-02-2012 6:41 PM
Quote Edit: managed to get the profile from http://windows.mouselike..../be/?DoAction=BrasChecker
I just tried this to see if that will give me my profile (although I'm pretty sure its whats its always been) out of curiosity and that also failed just like the bt speed test
