ZyXEL router wireless performance (FTTC 80/20 trial)
- Full Fibre
- Re: ZyXEL router wireless performance (FTTC 80/2...
09-03-2012 1:59 PM
From my initial testing, it's likely to end up back in its box.
Testing with Speedtest.net, I get fairly consistent speeds with both the Netgear N150 and the ZyXEL NBG4604.
The Netgear averages around 38mbps.
The ZyXEL averages around 26mbps.
On the plus side, speedtest.net has my wired connection at 74mbps and all connections at 17mbps up
Re: ZyXEL router wireless performance (FTTC 80/20 trial)
14-03-2012 7:09 PM
16-03-2012 3:43 PM
http://www.speedtest.net/result/1837782252.png
40.04 Mb down
9.16 Mb up
16 ms ping
hoping it will get better
steve
18-03-2012 11:11 AM
The big benefit for me over the Netgear are the connections for aerials, OK so the ones that come with it are shocking but a well spent fiver on eBay can get you much better aerials and therefore better coverage.
Oh the v1.00 doesn't give me a lot of confidence but we will wait and see upgrade to 80/20 on Tuesday.
Do I have to reboot the modem or anything?
18-03-2012 4:29 PM
However, the laptop only managed about 13mbps up.
So, it looks like if the client talks to the router using the right magic incantation, it is capable of utilising the full connection speed with the ZyXEL (subject to it's 100mbps wan port).
When my line was switched I didn't reboot the modem, and everything worked properly.
20-03-2012 7:54 AM
Do I have to reboot any kit?
20-03-2012 2:01 PM
I've just double checked on your account and can see that the order for 80/20 has gone through.
I'd advise that you reboot the modem and check again, failing that please raise a fault: https://portal.plus.net/apps/kbdfaults
If you do have to go down that route I'd appreciate a heads up on this thread as there is a group of other customers experiencing speed faults on the trial: http://community.plus.net/forum/index.php/topic,102776.576/topicseen.html
21-03-2012 7:44 AM
Done some powering down of the router and modem. No dice.
Results currently:
BTs test gives approximately the same. Not a wiring issue as nothing has changed, in fact I went to work and it was 36mbps came home and it was 16mbps. IP profile stuck on the 17.5 setting.
23-03-2012 7:27 AM
speeds have not changed , still getting about 40 down and 9 up with 20ms ping
spoke to tech support/ faults, was told not to use speedtest.net but the bt site instead due to bandwith abilities
results came back the same. was then told to come on here and discuss ....
is this the average speed we are getting on the trial? not that im unhappy with 40Mb but just to show what im getting
the Fibre cabinet is about 1/4 mile from me at end on the lane
steve
23-03-2012 9:09 AM
@moonmelon1
You will be better posting in the 80/20 trial thread as this is dealing with speed problems.
You should run the full BT speedtester and make a note of your IP Profile. From this you will know what speeds you should be getting given your line.
23-03-2012 10:15 AM
Can you confirm that you used the beta speedtester (for connections above 24mb) on http://www.speedtester.bt.com/ when you tried this.
04-04-2012 8:20 AM
Wired downstream: 76Mbps
Wired Upstream: 16Mbps
Wireless downstream: 69Mbps
Wireless upstream: 16Mbps
Wireless sync speed to Modem: 150Mbs (802.11n)
So far the connectivity has been very consistant and stable so i cannot fault that. I''ve not seen any real benefit in moving up from 40/10 to 80/20 except for the upstream which has more than doubled for me. I wish we were given the option of installing our own VDSL Modem, this would then give us the ability to view the actual sync speeds etc.
Plusnet, i'm open to testing any other routers.
Regards
Mo..
- Full Fibre
