80/20 Trial - First day and 2nd Day - Very impressed with Speeds and Zyxel
- Full Fibre
- 80/20 Trial - First day and 2nd Day - Very impress...
27-03-2012 9:42 PM
Re: [FTTC] 80/20 Trial - First day
28-03-2012 10:08 AM
28-03-2012 9:02 PM
http://speedtest.net/result/1861624251.png
Well ive just connected the Zyxel and the speeds are pretty much the same as earlier (wifi connection)
Zyxel was very easy to setup and ive found the wifi signal is excellant around the home, pc upstairs connted to it is showing 300mb and a speed test carried out upstairs conneced via wifi was excellant same as the wired connection above
Overall very impressed with the Zyxel shame i cant get the full 80mb but who would complain as few weeks back i was getting 8mb via adsl
Kev
Re: 80/20 Trial - First day and 2nd Day - Very impressed with Speeds and Zyxel
28-03-2012 10:03 PM
Your speeds are very similar to mine and I'd be interested to know if you are similar distance.
28-03-2012 10:50 PM
Quote from: walker23 Any idea how far you are from your cabinet?
The cabinet is at the top of my road id say approx 1/4 of a mile to 1/2 a mile
Kev
28-03-2012 10:56 PM
I recon I'm a bit less than 1/4 mile but I'd need to try to measure it a bit more accurately.
29-03-2012 10:09 PM
Kev
31-03-2012 10:31 PM
01-04-2012 11:46 AM
Kev
01-04-2012 12:43 PM
FTTC Stats before 80/20 Trial
IP Profile: 38.72Mbps (as reported by speedtester.bt.com)
Downstream throughput: Typically 31 to 34Mbps
Upstream throughput: ~8Mbps
FTTC Stats during 80/20 Trial
IP Profile: 40.63Mbps (as reported by speedtester.bt.com)
Downstream throughput: Typically 31 to 37Mbps
Upstream throughput: Typically 8.3 to 9.7 Mbps
03-04-2012 3:38 PM
03-04-2012 6:20 PM
04-04-2012 12:37 AM
« Reply #10 on 03/04/2012, 15:38 »
> "i can't get that speedtester.bt.com to work..."
You are not alone. I have had problems with BT's speedtester recently too.
- Full Fibre
