upgrade to fibre extra speed low
OskarPapa
Fixes: 65
Re: upgrade to fibre extra speed low
Don't worry if you've not had time to do it as yet - there's no deadline or anything like that.
For reference, we're showing that the router is 'in sync' at 59.6mbps.
Lucyb09
hey , just had a bit of time to do a wired test and post the results, pic attatched
Fixes: 1,602
Thanks for getting back to us @Lucyb09
It looks like a prompt from Microsoft is blurring the screenshot you've posted.
Could you try that one more time please?
[edit]
Ignore me, the Microsoft pop up wasn't in the image it was a pop up on my PC. Roll_eyes
I'm looking into this further and will add another reply soon.
[edit 2]
Were there any other devices using your broadband connection or any background tasks open on the laptop/computer you were using at the time you completed that speed test?
Lucyb09
Nope I made sure their wasn't and I was the only one home today
Beyhive
Fixes: 44
Hi @Lucyb09,
I have updated the fault ticket, please click here to view my response.
 Faris
