slowing Fibre Broadband NEW Customer
FIXED- Subscribe to RSS Feed
- Re: slowing Fibre Broadband NEW Customer
- « Previous
- Next »
05-07-2016 4:45 PM
Have you still been seeing the same speed fluctuations over an ethernet connection since the 3rd?
on 09-07-2016 8:17 AM - last edited on 09-07-2016 8:28 AM by dvorak
Hi chris,
I had a message from [CSA Removed] at Plusnet to say some changes had been made on the 6th July, on the 5th I was getting 9.05Mb then the 8th (after the change) 17.16Mb and this morning at 7.57am 39.26Mb, probably the fastest ever!!! So if this is stable around this speed I will be very happy :0)
I will keep monitoring and see how it goes.
Thanks for your help.
Moderator's note by Adie (Dvorak) CSA name removed as per Forum rules
11-07-2016 9:01 AM
That sounds much better!
- « Previous
- Next »
