setting up hub one
- setting up hub one
- « Previous
- 1
- 2
- Next »
Re: setting up hub one
02-07-2017 9:44 PM
Did you move the 5GHz onto a different SSID?
Which O/S are you using? If its Windows are you using the manufacturers drivers or the default Windows one?
02-07-2017 10:04 PM
I did change the SSID, my Iphone picks up 5GHz but my laptop won't that only detects 2.4GHz, I have windows 8.1 drivers are I assume default.
03-07-2017 11:24 AM
03-07-2017 12:58 PM
Yes, you can get short USB ones which are fairly cheap. Worth trying to see if it fixes the problem.
03-07-2017 10:28 PM
I borrowed two laptops from work today and they were getting speeds of 45+ GHz this made me think that its my laptops at fault, So ! on the note of wifi cards I looked for more information and ended up in the network adapter settings where I found the wifi to be set on performance, the other option was wifi so I thought well I'll give it a try and low and behold I am now getting a constant 50+mbps on 2.4 GHz.
So I am now all fixed and cooking on gas! I just have to check the settings on my other two laptops to make sure the settings are correct on those.
Thanks to all that tried to help, I'm sure that without you I would have given up long ago.
04-07-2017 6:58 AM
Glad you got there in the end, and glad that we were able to help you... even though it did all sound rather technical and daunting.
04-07-2017 12:40 PM
- « Previous
- 1
- 2
- Next »
