password problems
patti
password problems
Hi, I'm having problems signing in.. every time I try it doesn't recognise my password and I have to reset every time? Any suggestions please?
8 REPLIES 8
SpiritualBeggar
Re: password problems
Apologies for the hijack but I'm having the exact same problem.
adamwalker
Fixes: 222
Were you having issues signing into the member centre or was it connecting to broadband perhaps?
 Adam Walker
Fixes: 1,485
Moved:
Ben1
Me too, having to reset my password EVERY time I log in is getting tiresome.
adamwalker
Fixes: 222
Hi all,
Can I ask anyone experiencing this issue (already posted or otherwise) to clarify what you're trying to log into?
For example are you trying to connect or trying to log into our website perhaps?
 Adam Walker
Riza
Connecting via community works, member center works and so does the ppoe plusdsl account.
Cannot see anything wrong here? Thumbs_Up
If you're having trouble logging into any of the Plusnet sites, do try to clean your browser's login cookies and cache so that it will a fresh loaded page instead of one local cached one. Also, to load the page without cache you can hold Ctrl and then press f5.
Ben1
It happens to me on https://community.plus.net/ (but not on https://www.plus.net/)
My pw isn't recognised and I have to reset it in order to be able to log in (to https://community.plus.net/)
Anotherone
Champion
Fixes: 21
A reminder that the password for the Portal/Member Centre & Broadband connection is not the same as the  Community Site - unless you have set the two the same - not advisable. If you reset/change your Community Site password you must use the  link in the reset email.
