Technicolor TG582n Internet keeps dropping
carlwinkle
Red light keeps showing for Internet on my Technicolor TG582n, keeps dropping maybe every 10mins for approximately 1-2mins. Very frustrating, any ideas?
bill888
Seasoned Pro
Fixes: 24
Re: Technicolor TG582n Internet keeps dropping
Just some ideas.
It could be a line fault, or your equipment is failing/overheating if they are several years old.  Failing power adapters being very common.
Check the lights on the Openreach modem, particularly the Power and DSL light for clues.
geek26
If the lights are also affected on your openreach modem please raise a fault at: faults.plus.net this will allow for investigations to take place by the faults team and enable this to be resolved asap
Many thanks,
James
