line speed
staceyd86
line speed
hi in connected at 77124 but line speed is only 70mb can someone update this for me ?
14 REPLIES 14
staceyd86
Re: line speed
and also is there a update for my hubone ?
Software version 4.7.5.1.83.8.237.2.2 Last updated 08/09/17
Fixes: 1,483
Re: line speed
Yes, that’s the latest firmware version
Fixes: 1,600
Re: line speed
Hi there.
I've updated your speed profile now. If you do a single disconnect/reconnect in your routers interface you should have a slightly improved throughput.
In addition, our tests are showing a potential line fault which might be why your speeds dropped previously.
I've raised this with our suppliers and we'll update you when we know more.
staceyd86
Re: line speed
Thanks. Any will you let me know on this post on any updates with the fault please
MasterOfReality
Fixes: 57
Re: line speed
Hi @staceyd86
The fault that @Gandalf raised to our suppliers will be updated on your account - you can view this by clicking here
Hope this helps!
staceyd86
Re: line speed
faults been fixed now and syncing at....
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:05:17
6. Data rate: 20000 / 78330
7. Maximum data rate: 27404 / 78472
8. Noise margin: 9.9 / 6.0
9. Line attenuation: 13.6 / 11.2
10. Signal attenuation:
13.3 / 11.2
can you please update my profile speed again as it has went back to 70mb after its went down to be fixed
Fixes: 1,600
Re: line speed
I've just done that for you now.
If you reboot your router you should see improved speeds.
staceyd86
Re: line speed
can you do my line speed again please,
Data rate:
20000 / 78571
line speeds set to 73mb
staceyd86
Re: line speed
its gone to 76mb now but should it not be set to 79mb ?
staceyd86
Re: line speed
can anyone sort this please ?
Browni
Aspiring Hero
Fixes: 60
Re: line speed
I don't think they put it above 78Mb manually, they wouldn't for me.
staceyd86
Re: line speed
ive had it above 76mb, can a admin do this for me please ?
MatthewWheeler
Fixes: 479
Re: line speed
From what I can see this has now updated?
You may need to log into the router and disconnect then reconnect to pick the new profile up.
 Matthew Wheeler
staceyd86
Re: line speed
its still at 76mb profile
