imgur.com been slow all week now unreachable
- imgur.com been slow all week now unreachable
Re: imgur.com been slow all week now unreachable
30-01-2016 4:49 PM
Quote from: lwhitworth
Quote from: jmac80
Quote from: lwhitworth A VPN would be a solution yeah, but you'd never get me using a free VPN service, which means looking at a paid solution for something that should be working anyway
Never used to VPN (never needed to) so all new to me.
What would be wrong with a free VPN, Unreliable?
My asus router has a section for openVPN any use?
I see it more as a privacy issue tbh. If I'm going to be routing all my traffic through someone I want some contract in place!
What VPN do you use recommend?
30-01-2016 4:55 PM
30-01-2016 5:00 PM
Same goes for imgur, when it is trying to connect to hwcdn, it fails to load.
30-01-2016 5:03 PM
Quote from: jmac80
Quote from: jmac80
Check out www.proxpn.com
30-01-2016 5:30 PM
30-01-2016 5:40 PM
If we can provide anymore information in this thread it might make it easier for them. If someone knowledgeable could do a summery that would help too.
30-01-2016 6:38 PM
30-01-2016 6:39 PM
dick:quote
30-01-2016 8:06 PM
30-01-2016 8:25 PM
Hope to see this fixed soon, noticed over the last week there was an issue with a few other sites as well but just assumed it was those sites until today.
Doesn't seem to be a specific gateway either, reconnected a number of times today to gateway hop, had at least 5 different gateways (bng01, 02, 04 and a couple of non-bng ones) and it was the same issue for all of them.
30-01-2016 9:00 PM
30-01-2016 9:29 PM
30-01-2016 9:31 PM
Comparison:
Plusnet:
$ time wget http://m.imgur.com/6HoZi0o.jpg
--2016-01-30 21:25:21-- http://m.imgur.com/6HoZi0o.jpg
Resolving m.imgur.com (m.imgur.com)... 185.31.18.193
Connecting to m.imgur.com (m.imgur.com)|185.31.18.193|:80... connected.
HTTP request sent, awaiting response... 302 Found
--2016-01-30 21:25:21-- http://imgur.com/6HoZi0o.jpg
Resolving imgur.com (imgur.com)... 185.31.19.193
Connecting to imgur.com (imgur.com)|185.31.19.193|:80... failed: Connection timed out.
Retrying.
--2016-01-30 21:27:29-- (try: 2) http://imgur.com/6HoZi0o.jpg
Connecting to imgur.com (imgur.com)|185.31.19.193|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
--2016-01-30 21:27:38-- http://i.imgur.com/6HoZi0o.jpg
Resolving i.imgur.com (i.imgur.com)... 185.31.18.193
Reusing existing connection to m.imgur.com:80.
HTTP request sent, awaiting response... 200 OK
Length: 1038102 (1014K) [image/jpeg]
Saving to: ‘6HoZi0o.jpg’
6HoZi0o.jpg 100%[=================================================>] 1014K 1.41MB/s in 0.7s
2016-01-30 21:27:39 (1.41 MB/s) - ‘6HoZi0o.jpg’ saved [1038102/1038102]
real 2m18.027s
user 0m0.008s
sys 0m0.012s
vs
converted 'http://m.imgur.com/6HoZi0o.jpg' (ISO-8859-1) -> 'http://m.imgur.com/6HoZi0o.jpg' (UTF-8)
--2016-01-30 21:29:22-- http://m.imgur.com/6HoZi0o.jpg
Resolving m.imgur.com (m.imgur.com)... 185.31.19.193
Connecting to m.imgur.com (m.imgur.com)|185.31.19.193|:80... connected.
converted 'http://imgur.com/6HoZi0o.jpg' (ISO-8859-1) -> 'http://imgur.com/6HoZi0o.jpg' (UTF-8)
--2016-01-30 21:29:22-- http://imgur.com/6HoZi0o.jpg
converted 'http://i.imgur.com/6HoZi0o.jpg' (ISO-8859-1) -> 'http://i.imgur.com/6HoZi0o.jpg' (UTF-8)
--2016-01-30 21:29:22-- http://i.imgur.com/6HoZi0o.jpg
Resolving i.imgur.com (i.imgur.com)... 185.31.19.193
Connecting to i.imgur.com (i.imgur.com)|185.31.19.193|:80... connected.
Saving to: '6HoZi0o.jpg'
6HoZi0o.jpg 100%[=====================>] 1014K --.-KB/s in 0.09s
2016-01-30 21:29:22 (10.7 MB/s) - '6HoZi0o.jpg' saved [1038102/1038102]
real 0m0.160s
user 0m0.032s
sys 0m0.036s
So thats 0.16s to get an image via another ISP versus 2m18s via plusnet. Get it together!
edit: here's a possible fix for chrome users for imgur:
- go to chrome://net-internals/#hsts in chrome
- in the 'add domain' section type 'imgur.com' and click add
- again in the 'add domain' section type 'm.imgur.com' and click add
this makes your browser rewrite all http requests to imgur to go via https, which cannot be man-in-the-middled by plusnet in such a botched way.
to undo the workaround go to that same chrome url and enter imgur.com and m.imgur.com into the delete section.
30-01-2016 9:56 PM
Quote from: jpixton
Yep, Thank you for the work around!
30-01-2016 10:32 PM
