graph
jockwav
graph
I don,t know what they actually mean or how to read them. Smiley
Your Shared Graph
34cad52545c17385d3b852881e8d3ee3
Logged in as: jasbin | Logout | My Profile
New to Broadband Guide
Monitor Slow Broadband
Broadband Speed Test
Follow @thinkbroadband on twitter
https://www.flickr.com/photos/james_bingham/
9 REPLIES 9
Fixes: 62
Re: graph
jockwav
Re: graph
does not mean a lot to me. Grin Cheesy
SpendLessTime
Aspiring Hero
Fixes: 82
Re: graph
Assuming you used the right IP address and that your internet connection is working, the solid red block may mean that your router in not answering the pings sent out by ThinkBroadBand.
Which router are you using as some routers will ignore pings sent to them (eg The Plusnet Hub One)?
jockwav
Re: graph
Its the PN one, TG582n
Fixes: 62
Re: graph
jockwav
Re: graph
It was set at disabled,so i have enabled it now.
jockwav
Re: graph
When i try to make a new one it says,You are already monitoring this IP address
SpendLessTime
Aspiring Hero
Fixes: 82
Re: graph
Well you are monitoring that address and as you've enabled replying to pings on the router, the graph is slowly showing green on the right side as time passes.
jockwav
Re: graph
Ah right, so is that it working now. Smiley
