Fibre speed drops every evening and BQM shows packet drop
- Fibre speed drops every evening and BQM shows pack...
03-01-2016 10:06 AM
Before I gateway jump - are Plusnet interested
Re: Fibre speed drops every evening and BQM shows packet drop
03-01-2016 10:24 AM
It's not too uncommon just after XMAS, with all the new devices etc. using the internet.
03-01-2016 10:29 AM
03-01-2016 11:02 AM
03-01-2016 11:15 AM
03-01-2016 8:22 PM
Gateway hop You are currently connected to gateway pcl-ag02.
Tomorrow I will try a resync
03-01-2016 11:31 PM
Though,as i after several similar less frequent issues suffered some 5 mths of continuous peak time issues i gave up with PN and took it higher to their arbitration CISAS shortly afterwards i migrated away ,
As the proverb goes,"You only gets what you pays for ",at the end of the day, Is very true , doesn't mean that you aren't entitled to complain though, Plusnet aren't really charging enough for it to be truly viable (FTTC prices) Despite what ANDY-H will say , Hey Andy My throughput didn't drop during xmas and new year so your theory doesn't really hold much water , nor should it be accepted as normal if it did, But there again i pay more and get more in the way of support and service levels , with my current isp
In comparison would you build a gaming spec PC using inferior parts , and expect it to provide stellar performance for years without issues ?
And PN could return to a good ISP if they ceased trying to compete with the Harding's and started charging a fair price for their BB products , a price that would pay for reasonable support levels, and service levels , and then they could charge a lot less than their brethren BT consumer for line rental &calls
04-01-2016 12:25 AM
Quote from: deathtrap As the proverb goes,"You only gets what you pays for "
True, but there will be a wide variation of what PN customers are paying. The 'you only get what you pay for' argument won't wash with someone on a Market 1 exchange paying full price for FTTC.
04-01-2016 6:49 AM
04-01-2016 10:31 PM
You are currently connected to gateway ptn-bng02.
Tonight there are no problems with either the BQM graph or Samknows Testing and the speed test is fine
So what changed and I have a theory
The previous resync was immediately after a power cut and this was the effect
My download speed is normally more or less stable between 45.5 and 47.5Mbps depending on the time of day/weather/etc. when it resyncs Upstream is also stable at about 8.5Mbps
When the power came back on the router (8800NL) reconnected but with a speeds of 47620/12200 and the upload noise margin is now varying between 1.8 and 2.3 instead of the normal around 6dB and even though the error seconds are higher the DLM system appeared happy.
So how can this cause the stupid results
