gea test please
iangilf
gea test please
hi can i have an upto date gea test please
thankyou
26 REPLIES 26
SammyM
Fixes: 96
Re: gea test please
Hello Ian
I have run a speed test on your line and its shows the current speed going down your line is 75.4 Mbps, which can be seen below.Please get in touch if you experience any problems Smiley.
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 75.4 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Target Fix Time
Fault Report Advised N
Estimated Line Length In Metres 377.3
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-01-09T15:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 75.3 Mbps 75.3 Mbps 75.3 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 900.0 Sec 900.0 Sec 900.0 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-01-22T14:33:07.792+00:00 2018-01-22T14:48:07.792+00:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 2 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Sammy M - Sheffield Team
iangilf
Re: gea test please
thanks sammy Smiley
Fixes: 1,601
Re: gea test please
No problems Ian.
Please let us know if you need any further assistance.
mike360
Re: gea test please
Can i have gea line test please. thanks
SammyM
Fixes: 96
Re: gea test please
Good morning @mike360
Below is an up to date GEA test. Please let us know if you need any further assistance. Smiley
Test Outcome Pass
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 10.0 Mbps
Estimated Line Length In Metres 716.3
Technology VDSL
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-01-11T10:30:00
Down Stream Line Rate 39.9 Mbps 39.9 Mbps 39.9 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Start Time Stamp 2018-01-24T09:57:50Z 2018-01-24T10:12:50Z
Errored Seconds 0 0
iangilf
Re: gea test please
hi bt engineer came today did some fixes stats are
5. VDSL uptime: 0 days, 06:32:00
6. Data Rate: 20000 / 75526
7. Maximum Data Rate: 28516 / 76067
8. Noise Margin: 10.1 / 6.3
9. Line Attenuation: 16.8 / 13.9
can i have a upto date gea test please when u can get around to doing one please
adamwalker
Fixes: 221
Re: gea test please
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Sync Status In Sync
Downstream Speed 78.0 Mbps
Estimated Line Length In Metres 339.1
Technology VDSL
Time Stamp 2018-02-22T12:00:00
Down Stream Line Rate 75.5 Mbps 78.0 Mbps 76.8 Mbps
Up Time 863.0 Sec 900.0 Sec 899.5 Sec
Retrains 0.0 1.0 0.0
Start Time Stamp 2018-02-23T11:18:29.263+00:00 2018-02-23T11:33:29.263+00:00
Ingress Code Violation 0 21
Errored Seconds 1 4
0
Moderator's note by Adie (Dvorak) removed identifier
 Adam Walker
iangilf
Re: gea test please
Ok thanks
adamwalker
Fixes: 221
Re: gea test please
No worries, how did the engineer visit go?
 Adam Walker
iangilf
Re: gea test please
I wasn't in mate but left a note for them to read and apparently there was something wrong in the cab so did a lift and shift so see how that goes now syncing higher so fingers crossed it sorts the problem also fitted bt socket so fingers crossed it stays that way cheers mate
adamwalker
Fixes: 221
Re: gea test please
No worries, feel free to tag me after I'm back on shift next Tuesday and I'll be happy to review the situation with you.
 Adam Walker
iangilf
Re: gea test please
mate my speeds are dropping constantly again from 80 to this now
1 Days, 0 Hours 22 Minutes 49 Seconds
20.00 Mbps / 65.27 Mbps
25755 / 66892
9.4 dB / 6.3 dB
14.2 dB
0/38
G_993_2_ANNEX_B
what is the causes of this its been pretty good up until now again where my speeds are continuing to drop yet again ?
MasterOfReality
Fixes: 57
Re: gea test please
Hi @iangilf
I'll run some tests now and update the thread with my results - please bear with me
Thanks,
Alisdair
MasterOfReality
Fixes: 57
Re: gea test please
Test Outcome
Pass
Sync Status In Sync
Downstream Speed 65.3 Mbps
Estimated Line Length In Metres 353.4
Interference Pattern Regular Interference Observed on Week Days
Service Impact Retrains Observed
Interference Duration Longest Occurrence From 20:00 to 20:30
Interference Location Unknown
Technology VDSL
Time Stamp 2018-04-24T10:45:00
No issues have been identified in the BTW network
KBD tests indicate no BTW network fault
I can see that your router is syncing at 65.3Mbps which is well within the limits for your line of 61 - 80 Mbps.
For good measure, I also ran a specific WLR3 test to see if there was anything on the narrowband side which could be affecting this, and I'm please to report that no fault was found.
This visual RADIUS readout shows a few isolated drops in connection over the weekend, but nothing which is giving me any specific cause for concern.
I hope this has given you the information you were looking for, however, if you wish to know anything else please don't hesitate to get back in touch.
All the best,
Alisdair
