gea test please
- gea test please
gea test please
22-01-2018 12:59 PM
hi can i have an upto date gea test please
thankyou
Re: gea test please
22-01-2018 2:56 PM - edited 22-01-2018 3:43 PM
Hello Ian
I have run a speed test on your line and its shows the current speed going down your line is 75.4 Mbps, which can be seen below.Please get in touch if you experience any problems .
Test Outcome | Pass | |
Test Outcome Code | GTC_FTTC_SERVICE_0000 | |
Description | GEA service test completed and no fault found . | |
Main Fault Location | OK | |
Sync Status | In Sync | |
Downstream Speed | 75.4 Mbps | |
Upstream Speed | 20.0 Mbps | |
Appointment Required | N | |
Fault Target Fix Time | ||
Fault Report Advised | N | |
Estimated Line Length In Metres | 377.3 | |
Upstream Rate Assessment | Very Good | |
Downstream Rate Assessment | Reasonable | |
Interference Pattern | Not Detected | |
Service Impact | No Impact Observed | |
Home Wiring Problem | Not Detected | |
Downstream Policing Discard Rate | 0.0 | |
Customer Traffic Level | Upstream and Downstream Traffic Detected | |
Technology | VDSL | |
NTE Power Status | PowerOn | |
Voice Line Test Result | Pass | |
Bridge Tap | Not Detected | |
Radio Frequency Ingress | Not Detected | |
Repetitive Electrical Impulse Noise | Not Detected | |
Cross Talk | Not Detected | |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | |
Time Stamp | 2018-01-09T15:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 75.3 Mbps | 75.3 Mbps | 75.3 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-01-22T14:33:07.792+00:00 | 2018-01-22T14:48:07.792+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 2 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Re: gea test please
23-01-2018 5:12 AM
thanks sammy
Re: gea test please
23-01-2018 1:05 PM
Re: gea test please
24-01-2018 9:53 AM
Can i have gea line test please. thanks
Re: gea test please
24-01-2018 10:26 AM
Good morning @mike360
Below is an up to date GEA test. Please let us know if you need any further assistance.
Downstream Speed | 40.0 Mbps | |
Upstream Speed | 10.0 Mbps | |
Estimated Line Length In Metres | 716.3 | |
Downstream Rate Assessment | Very Good | |
Profile Name | 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off | |
Time Stamp | 2018-01-11T10:30:00 |
Down Stream Line Rate | 39.9 Mbps | 39.9 Mbps | 39.9 Mbps |
Up Stream Line Rate | 9.9 Mbps | 9.9 Mbps | 9.9 Mbps |
Start Time Stamp | 2018-01-24T09:57:50Z | 2018-01-24T10:12:50Z |
Re: gea test please
22-02-2018 5:55 PM
hi bt engineer came today did some fixes stats are
5. | VDSL uptime: | 0 days, 06:32:00 |
6. | Data Rate: | 20000 / 75526 |
7. | Maximum Data Rate: | 28516 / 76067 |
8. | Noise Margin: | 10.1 / 6.3 |
9. | Line Attenuation: | 16.8 / 13.9 |
can i have a upto date gea test please when u can get around to doing one please
Re: gea test please
on 23-02-2018 11:48 AM - last edited on 09-05-2018 7:02 AM by dvorak
GEA Test Detail |
Circuit ID | NA | Service ID | |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 78.0 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 339.1 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-02-22T12:00:00 |
Down Stream Line Rate | 75.5 Mbps | 78.0 Mbps | 76.8 Mbps |
Up Time | 863.0 Sec | 900.0 Sec | 899.5 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Start Time Stamp | 2018-02-23T11:18:29.263+00:00 | 2018-02-23T11:33:29.263+00:00 |
Ingress Code Violation | 0 | 21 |
Errored Seconds | 1 | 4 |
0 |
Moderator's note by Adie (Dvorak) removed identifier
Re: gea test please
23-02-2018 12:33 PM
Re: gea test please
23-02-2018 12:38 PM
Re: gea test please
23-02-2018 1:18 PM
Re: gea test please
23-02-2018 2:52 PM
Re: gea test please
07-05-2018 10:29 AM
mate my speeds are dropping constantly again from 80 to this now
1 Days, 0 Hours 22 Minutes 49 Seconds
20.00 Mbps / 65.27 Mbps
25755 / 66892
9.4 dB / 6.3 dB
14.2 dB
0/38
G_993_2_ANNEX_B
what is the causes of this its been pretty good up until now again where my speeds are continuing to drop yet again ?
Re: gea test please
07-05-2018 10:37 AM
Hi @iangilf
I'll run some tests now and update the thread with my results - please bear with me
Thanks,
Alisdair
Re: gea test please
07-05-2018 11:03 AM
Test Outcome |
Pass |
Downstream Speed | 65.3 Mbps |
Estimated Line Length In Metres | 353.4 |
Interference Pattern | Regular Interference Observed on Week Days |
Service Impact | Retrains Observed |
Interference Duration Longest Occurrence | From 20:00 to 20:30 |
Interference Location | Unknown |
Technology | VDSL |
Time Stamp | 2018-04-24T10:45:00 |
No issues have been identified in the BTW network
KBD tests indicate no BTW network fault
I can see that your router is syncing at 65.3Mbps which is well within the limits for your line of 61 - 80 Mbps.
For good measure, I also ran a specific WLR3 test to see if there was anything on the narrowband side which could be affecting this, and I'm please to report that no fault was found.
This visual RADIUS readout shows a few isolated drops in connection over the weekend, but nothing which is giving me any specific cause for concern.
I hope this has given you the information you were looking for, however, if you wish to know anything else please don't hesitate to get back in touch.
All the best,
Alisdair
