fibre profiles question with my account
- fibre profiles question with my account
30-12-2014 5:52 PM
Estimated line speed:
74Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-12-30 17:35:52
then this
66Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-12-30 17:45:52
and this is my current speed
So why has my profile been dropped in a matter of a few mins ?
then this
Message 1 of 5
(789 Views)
4 REPLIES 4
Re: fibre profiles question with my account
30-12-2014 6:13 PM
it may not have done as the estimated line speed is notoriously flakey
the only way to check your profile is via the BT speedtest
Message 2 of 5
(423 Views)
30-12-2014 7:03 PM
Hi St3,
That's the estimates rather than the profile for your line. The profile is still at 77.4Mb, hence the speed still being at a high level.
Message 3 of 5
(423 Views)
30-12-2014 9:38 PM
ok thanks
Message 4 of 5
(423 Views)
31-12-2014 3:58 AM
BT are known to make changes to their estimates, as they get a clearer idea of what your line is like - and what it considers a "comparable set of lines" to compare it against. They then give your line an estimate range that runs from the 20% to 80% percentiles of that set.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 5 of 5
(423 Views)
