capacity issues - continued
- capacity issues - continued
Re: capacity issues - continued
21-08-2015 1:18 AM
It looks like [Censored], not selling Pulse8 much thats for sure...
I think he's rural, I know he's on a market 1 exchange that has had TT LLU added to it... we had a very long qnd heated discussion about it one night...
He also mentioned that there was a lot of human intervention from Openreach in the area potentially trying to fix a plague of issues as the PCP and ground chambers...
21-08-2015 1:21 AM
Congestion is what that is showing surprise , surprise , BTW me thinks is possibly the culprit better do a TAP3 and report it to tech support via phone it is their job to take this up with BTW as they are BT's customer , but if pn will do enough pushing of BTW to get a resolution is a different kettle o fish
Quote from: The Turn's out tonights issue was far worse than I thought.... I've just checked my BQM's!
Ouch... I never get this!
21-08-2015 1:23 AM
Quote from: deathtrap you couldn't do any serious online gaming on that connection in particular when the host server is located in europe and usa
I've not been able to play online gaming properly on my connection for quiet some time... lots of rubber banding and general lag.
Been through so many different setups and nothing has improved anything
21-08-2015 1:25 AM
Quote from: deathtrap Congestion is what that is showing surprise , surprise , BTW me thinks is possibly the culprit better do a TAP3 and report it to tech support via phone it is their job to take this up with BTW as they are BT's customer , but if pn will do enough pushing of BTW to get a resolution is a different kettle o fish
Bollox to it anyway... I've been planning to avoid BTw since the issues with Plusnet began...
21-08-2015 8:48 PM
TBBQM:
Disconnect visible at start, apparently successful speed test just before the packet loss started.
Anyway I restarted the router (it doesn't have a disconnect button on its UI) and now everything is back where it should be. So it looks like I'm encountering this issue every two to three months and can fix it in two minutes. Annoying..but not yet enough to make me want to risk committing to a new ISP.
21-08-2015 8:59 PM
You are currently connected to gateway ptw-bng01.
Gateway hop
You are currently connected to gateway ptw-ag01.
Note - the drop in latency was when G.INP was enabled on my cab
Just to add the reported error seconds dropped from 3 to 4 an hour to 1 per hour after the gateway hop
21-08-2015 10:19 PM
It is clear what the symptoms are here. It is also clear a gateway hop can often resolve the issue. It is crystal clear there is a problem and you really need to be providing an update on what you are doing to resolve this.
I believe you have already acknowledged an issue exists, so I don't think that is up for debate any more.
I think all the contributors to this thread would just appreciate if you would come on and give an honest update. If there is no momentum within the organisation to resolve this issue, please have the courtesy to come on and say so. At least that way customers can make an informed choice as to whether they want to stick with Plusnet.
What is not acceptable is silence on this issue.
We know the forum staff will read this, so please can we have a response?
21-08-2015 10:21 PM
21-08-2015 11:54 PM
Jumped gateway... 7/8 times... 4 times it just kept pushing me back to PCL-BNG01... finally got it onto PTN-BNG01... see how long that lasts....I suppose..
Issues rectified after the hops BTW, so it was something to do with PTW-BNG01 by the looks of it!
22-08-2015 12:03 AM
I am not sure how much of it is gateway related versus endpoint related.
22-08-2015 12:34 AM
Issues for me in the past have always been on PCL-BNG02.
22-08-2015 12:46 AM
22-08-2015 6:22 PM
Gateway 195.166.130.166
Gateway 195.166.128.172
Speed test wouldn't complete.
Dropped ppp and had trouble getting a new ppp session.
Gateway 195.166.130.165
TBB speed test failed.
Come on Plusnet, let us know what you're doing about this peak time slowdown.
Edit:
The above may have been made worse by a local thunderstorm, shortly after posting the above the power went off.
Thing are not as bad now, just back to the usual Plusnet peak time rubbish.
Gateway ptn-ag04
Gateway 195.166.130.142 (pcl-bng01)
At least the speed test result is now acceptable.
It's 9:30pm: lets see if the above TBB ping graph shows an improvement in packet loss.
22-08-2015 6:56 PM
http://www.thinkbroadband.com/speedtest/results.html?id=144026963715229731976 ; Hop time methinks
22-08-2015 11:02 PM
I'm on PTW-BNG01... AGAIN! I dropped off PTN-BNG earlier today and was then allocated a spot on PCL-AG07... but seems its been thrown out again!
My graphs a bit spikey, with moments of stress but packet loss seems to be to a minimum on TBB... thought that hasn't been the case on other routes unfortunately
