capacity issues - continued
- capacity issues - continued
24-06-2015 8:12 PM
So matt whats the update please, or is there nothing coming.
I suggest only those affected post here.
Re: capacity issues - continued
24-06-2015 10:08 PM
Talk about under-carpet brushing, as you say! Perhaps between us all we were edging too close to the truth.
Anyway, here's a wired speed test taken a few minutes ago. Compare and contrast with 22:19 last night, 22:30 last night, and one taken at 00:55 this morning when things had gone quiet. I used to have results like the last one all the time.
24-06-2015 10:25 PM
Speed tonight http://www.thinkbroadband.com/speedtest/button/143518198777828615545.png
Normal speed. http://www.thinkbroadband.com/speedtest/button/143513627192377938767.png
24-06-2015 11:19 PM
That speed result is seriously bad, I assume nothing else was running on your connection at the time, downloads etc.
What you should do is run the BTw Performance test - DON'T REBOOT, use an Ethernet (wired) connection, ignore the red preamble except make sure no other programs are using the Internet, and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test. But do it to get the bad result and don't run another once you have. The last results are visible to Plusnet on their systems.
Do a Copy and Paste of the results and post here (no need to grab an image). Then raise a fault at http://faults.plus.net/
25-06-2015 2:06 AM
25-06-2015 9:46 AM
25-06-2015 4:52 PM
Whereas I think it should have been closed a while back due to the unpleasant comments and personal attacks being banded around by some people. If posters can keep this thread polite and clean I'm sure it'll have a long life.
Quote from: chrcoluk Please continue discussing here, plusnet may prefer everyone to make their own threads for PR reasons, but collective posts are more effective at getting these issues resolved, even if plusnet want to brush them under the carpet.
Perhaps as long as the fault it is trying to have fixed. Six months..and counting
25-06-2015 5:03 PM
25-06-2015 5:06 PM
25-06-2015 5:08 PM
25-06-2015 5:13 PM
I just didn't want this thread to devolve in to single fault issues that have been added just due to it seeming like a similar issue as happened in the last one.
25-06-2015 5:27 PM
If so how can we be assured our ticket will not just timeout after 14 days and close...
25-06-2015 5:31 PM
If on a BNG gateway I see no issues at all during the day, but come 8pm to about 1am I will get 3-5% loss and speeds down around 4-7mbit verses my normal 30mbit. If not on a BNG I might see a drop in speed to 28mbit at peek times which is to be expected and no loss.
25-06-2015 7:05 PM
Please give an update asap Chris or Matt.
25-06-2015 9:42 PM
Normal Speed
Speed now
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
3.22 Mbps
0 Mbps 77.42 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.22 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-77.42 Mbps .
Additional Information:
IP Profile for your line is - 77.42 Mbps
Upload Speed
3.86 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 3.86Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
