Zoom and Microsoft Teams
dartilov
Re: Zoom and Microsoft Teams
Thanks for the reply.
I am assuming your comment, which is correct, that I have a BT Openreach modem, means that switching it to access point mode is not going to be the right thing to do.
What about the other suggestions?
Something is causing the issue as a video conference on 4G is fine, as soon as I use the internet be it wired or wireless the freezing happens instantly.  I can't seem to find what.
 though.
dartilov
Thanks for taking the time to reply again.
I don't have a BT Hub bit I have an ECI BT Openreach Modem so I don't think I can switch it to an access point can I?
Therefore the QoS will need to remain, I take it.
I will try the DoS, if not the other two.
Fixes: 397
@dartilov no, it doesnt, not all routers support it and enabling it can cause throughput degradation on many routers.  I would suggest that the first thing, as @Edinburgh_wg suggested, is to disable QoS and see if the situation improves.
Fixes: 419
No you can't.
Edinburgh_wg
You're switching the Archer to the Access Point mode, not your Openreach or BT modem!
QoS still stands to try out.
I don't understand your point with 4G. You didn't tell us what you're connecting to 4G? Your phone? If so, what is it meant to prove? That Whatsapp is working?
If your router/modem is being connected to 4G, then how are you connecting it? Are you using a dongle?
Fixes: 419
@Edinburgh_wg
You can’t connect an Access Point to a Modem. You need a router. The only router the OP has is the Archer in Router mode.
Edinburgh_wg
Maybe so, but OP is so cryptic about everything that is difficult to know what the set-up is.
No harm trying the Access Point mode, is there?
dartilov
Thanks for taking the time to reply again.  I am surprised you say I am so cryptic as it is not intended to be.  Perhaps on a help forum you may have also asked a better question to enable a better answer from me and as someone else has already said I was pretty clear about the ECI BT Open Reach modem.
The 4G issue was using a video conferencing call on a mobile 4G (Vodafone) network as opposed to the wifi to establish that no freezing was occurring, which it didn't.
dartilov
Good evening
Yes, the access point is certainly not the right mode.
I have tried disabling things and testing but to no avail sadly.  The loss on a speedtest is nearly 40 - 50% at times, therefore no wonder i am freezing.
I am now unsure what the issue is except it may be better just to go back to the old router and see if that sorts it.
