Yet again
- Yet again
Yet again
20-07-2015 7:40 PM
It has been about 5 days after having a site visit to be told that what I get is what you see only then to be told that I had never been turned on to the high speed fibre speed although I was paying for it. It was turned on and speed s increased. However now I am getting after using the same tests as the engineer used speed go down load 16.5, 7.69,7.33 anode i amp paying for 70 Mbps. Will some one at Plusnet have the curtesy to put things right.
Message 1 of 2
(367 Views)
1 REPLY 1
Re: Yet again
21-07-2015 10:49 AM
The testing I've been through isn't showing any issues, however we don't have any BT Speedtest results to reference.
Can you run the BT Speedtest here: http://speedtest.btwholesale.com/
Make sure you complete the 'further diagnostics' test after the first result.
Message 2 of 2
(177 Views)
