Wifi problem Again...
- Wifi problem Again...
16-09-2016 7:17 PM
Hi all, for some time now we have been experiencing problems with wifi, If I connect via ethernet all is good. However our connection drops by the minute or so. We have the hub one. We are getting the same on 3 laptops and multiple tablets within the house that we try. I have tried every channel and get the same result. In auto channel we get none or very little connection. We have been with Plusnet for just over a year so that shows how old the hub is. If we disconnect the laptop/tablet from internet then reconnect we usually get a good connection for a few minutes. Then back to no connection, web pages hanging and totally freezing etc. Could we have a faulty router ? the router is not on any extensions and is in the same room as our devices not near anything that could cause interference.
P.S It is driving us mad.
Re: Wifi problem Again...
16-09-2016 7:19 PM
First thing to try is to change the name of one of the 2 SSID (WiFi names). Add a number 5 to the 5GHz one so you can distinguish between the 2 names.
See this page and the section "How to check or change WIFi Settings". I believe you have to uncheck the section "Sync with 2.4Ghz" so that you can then change the SSID's.
16-09-2016 7:25 PM
Hi @SpendLessTime , thanks for popping in, neither of our laptops are 5ghz compatible, 2.4 only.
16-09-2016 7:30 PM - edited 16-09-2016 7:36 PM
Okay , but are the tablets/other devices you mentioned? Might be worth a try to disable the 5Ghz band totally to see if that improves things.
There is also the standard Plusnet page you get pointed to when you say "WiFi Issues" to a Plusnet staffer at https://www.plus.net/help/broadband/getting-the-best-wifi-signal/
Unfortunately there isn't a whole lot more to add about WiFi issues as they are infuriating and hard to track done.
Edit: to add last sentence
16-09-2016 7:39 PM
The tablets are 2.4 and 5ghz and still the same problems. I will take a look at the link , Thanks
16-09-2016 7:42 PM
I can not see how to disable 5ghz any where ?
16-09-2016 7:46 PM
got it I have disabled 5ghz, I will now reboot laptop and reboot router to see if it has changed anything. Thanks
16-09-2016 8:10 PM
16-09-2016 8:32 PM
It must have turned off the 2.4Ghz band too. Not good.
Is the section "Sync with 2.4Ghz" set to NO on the 5Ghz settings page ?
16-09-2016 8:42 PM
Why would the router have a disable wireless network box on both the 2.4Ghz and 5Ghz tabs which disabled all wireless connections?
Surely it should just enable/disable that band only? Puzzling unless the "sync to 2.4" also syncs the wireless network disable too.
16-09-2016 8:56 PM
Not a clue, however when I click on "advanced settings, I have a choice to click 2.4 and 5ghz, if I click on 5 ghz there is a choice to turn off/disable this ?
16-09-2016 9:00 PM
I will try turning off sync with 2.4. Thanks
16-09-2016 9:01 PM - edited 16-09-2016 9:02 PM
On the Advanced Settings Page,
- On the 2.4Ghz tab, set the Wireless network to ON
- on the 5Ghz tab, set Wireless network to OFF and the "Sync with 2.4Ghz" to OFF.
- Check on the 2.4Ghz tab and ensure that the Wireless network is ON
- Save the settings
And hope that only the 5Ghz is off
Edit: posts crossing
17-09-2016 9:57 AM
I did exactly this
- Save the settings
And my internet speed literally drops to zero. I have a couple of netgear routers in the house would they work ? I could try to see if it is a problem with the router.
17-09-2016 12:34 PM
If the netgear routers have a built in VDSL modem then yes. Might be good to prove or disprove the Hub One.
