Web pages intermittently loading slowly
- Web pages intermittently loading slowly
15-03-2016 4:03 PM
Does anyone have any clues as to what could be causing this issue. I'm on fibre and it feels like dial-up at times.
Re: Web pages intermittently loading slowly
15-03-2016 4:11 PM
Quote Voice fault suspected - contact Voice CP to progress copper issue
Having said this, the sync speed seems fine and the connection seems pretty stable.
15-03-2016 4:17 PM
15-03-2016 4:26 PM
15-03-2016 4:32 PM
15-03-2016 4:36 PM
15-03-2016 5:00 PM
My setup is that I have one of the openreach faceplates with the broadband socket on the top and the phone socket on the bottom. By use of a doubler, there are various extensions running around the house for the phone. The broadband cable is long and it goes from the hallway downstairs to upstairs in a bedroom where the BT Openreach modem is.
Before I go out and buy a new faceplate, I want to ask whether the problem could be anywhere in my internal wiring or is it definitely the faceplate?
15-03-2016 5:03 PM
15-03-2016 5:13 PM
I think I'll have to monitor the internet for a bit longer as this is all beyond me.
15-03-2016 5:20 PM
Quote from: Annie The broadband cable is long and it goes from the hallway downstairs to upstairs in a bedroom where the BT Openreach modem is.
If you're going to be testing/replacing other cables to see if this helps the issue, it may be worth altering this so the modem is connected via a short DSL cable near the master socket and then have a long Ethernet cable running upstairs to the router as I believe DSL cables are affected by degradation much more than Ethernet cables.
15-03-2016 5:26 PM
15-03-2016 5:41 PM
. "Doublers" and extention phone cables for the modem/ router are very likely to interfere with the router performance.
So, if you can operate the Modem as close to the master socket as possible on a very short RJ11 cable, see if that improves things. What modem / router combination are you using? BT Openreach modem and which router?
A possible solution to try - which my brother is using , is to keep the Openreach fibre VDSL modem as close as possible to the phone socket , on a short RJ11 cable , but to put the router where you need it on the end of a long Ethernet cable between modem and rouer. it May look Untidy but works well and the ethernet cable can run under carepet etc. They can be up 10 100mteres in length with no degredation in performance .
Phone extentions should not interfere with broadband as long as the faceplate is working as it should ,and the extention wiring is connected to the correct terminals: ie The Filtered ones which are pins or connectors marked 2 and 5 .
This is the back of a filtered faceplacte
Dont connect any phone extention to A & B and ignore 3 & 4
Hope this helps
15-03-2016 7:14 PM
15-03-2016 7:54 PM
15-03-2016 8:18 PM
