Was there an outage today?
- Was there an outage today?
02-10-2018 11:58 AM
Looking at my TBB graph today shows a 5 hour drop out this morning:
Luckily it seems the ip is a bit sticky, so it re- connected to the same one.
Mark
Re: Was there an outage today?
02-10-2018 12:13 PM
Probably overnight maintenance. Have a look at this link, lots of area codes affected.
https://status.zen.co.uk/broadband/maintenance-outage-details.aspx?reference=127449468
02-10-2018 12:19 PM
Thanks for that. Our code isn't there, but doesn't mean to say it wasn't affected.
Mark
02-10-2018 8:53 PM
I've had a look at your connection logs during that time and it actually shows a drop just after midnight and a reconnect about 40 minutes later (this was probably the maintenance - though I can't find anything reported). When it reconnected it the dropped again about half 5 and then reconnected again. Here's a visual of the radius logs for your connection:
When it reconnected after that midnight drop until the 5:30 drop there was data that is showing as transferred to so it does look like the connection was usable.
02-10-2018 9:33 PM
Thanks for the log. Very strange as to why the graph was showing total loss for that amount of time then.
Mark
03-10-2018 2:02 PM
06-10-2018 8:54 PM
So another 2 hour ish dropout today
Confused as to what is happening here?
Mark
06-10-2018 11:38 PM
07-10-2018 9:08 AM
Morning Bob. It it is the PN supplied router, and because it isn't configurable to allow pings, I have them sent to a Now TV box in the DMZ. Never had to do it this way before, as all other routers I have had allow ping from the router interface.
Mark
13-10-2018 9:36 AM
Another outage today, but I was here when it happened. It appears to be a router thing, so will open a new thread in the router section.
Mark
14-10-2018 6:08 PM
Hi @Marsfish
I can't see any drop of connection (save a very brief one at about 9.30am) - did you notice something longer?
Thanks,
MoR
14-10-2018 6:41 PM
That was me re- starting the router. As I mentioned, I have found it is a router wireless issue and have opened a new thread about it here.
Mark
