Was there an outage today?
Marksfish
Seasoned Pro
Fixes: 4
Looking at my TBB graph today shows a 5 hour drop out this morning:
5fd6afe72ca3d7d5d9435b66379825b638fea146-02-10-2018
Luckily it seems the ip is a bit sticky, so it re- connected to the same one.
Mark
11 REPLIES 11
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: Was there an outage today?
Probably overnight maintenance. Have a look at this link, lots of area codes affected.
https://status.zen.co.uk/broadband/maintenance-outage-details.aspx?reference=127449468
Marksfish
Seasoned Pro
Fixes: 4
Thanks for that. Our code isn't there, but doesn't mean to say it wasn't affected.
Mark
JOLO
Fixes: 77
@Marksfish,
I've had a look at your connection logs during that time and it actually shows a drop just after midnight and a reconnect about 40 minutes later (this was probably the maintenance - though I can't find anything reported). When it reconnected it the dropped again about half 5 and then reconnected again. Here's a visual of the radius logs for your connection:
When it reconnected after that midnight drop until the 5:30 drop there was data that is showing as transferred to so it does look like the connection was usable.
Marksfish
Seasoned Pro
Fixes: 4
Thanks for the log. Very strange as to why the graph was showing total loss for that amount of time then.
Mark
Fixes: 1,602
It's odd, let us know if it happens again.
Marksfish
Seasoned Pro
Fixes: 4
So another 2 hour ish dropout today
b5621a872c539687bd59ceb8603f3a7ac534593b-06-10-2018
Confused as to what is happening here?
Mark
bobpullen
Fixes: 316
What router are you using and do you have any other external monitors configured? Could it be that your router is rate limiting external ping requests?
Marksfish
Seasoned Pro
Fixes: 4
Morning Bob. It it is the PN supplied router, and because it isn't configurable to allow pings, I have them sent to a Now TV box in the DMZ. Never had to do it this way before, as all other routers I have had allow ping from the router interface.
Mark
Marksfish
Seasoned Pro
Fixes: 4
Another outage today, but I was here when it happened. It appears to be a router thing, so will open a new thread in the router section.
Mark
MasterOfReality
Fixes: 57
Hi @Marsfish
I can't see any drop of connection (save a very brief one at about 9.30am) - did you notice something longer?
Thanks,
MoR
Marksfish
Seasoned Pro
Fixes: 4
That was me re- starting the router.  As I mentioned, I have found it is a router wireless issue and have opened a new thread about it here.
Mark
