Very slow speeds on Fibre Broadband for months
jackiewolst
Hello, for a few months now our broadband speeds have been unbelievably slow, to the point where basic webpages wont even load. Been doing speed checks for about a month now and the average speed seems to be about 1 Mb/s.
Connected to the test socket and retried still the same issue. Also tried replacing the micro filters etc. Speed issues are also happening when using Ethernet to connect. When we first got Fibre we were regularly getting 70 Mb/s download speed so I'm not sure what the issue is. Tries ringing up a few times but the wait times have been exceptionally long and unfortunately I've never had the time to wait with work/kids.
Regards Jackie.
Fixes: 162
Re: Very slow speeds on Fibre Broadband for months
Testing your line isn't showing any obvious issues:
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 251.2
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-02-09T14:00:00
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
 Chris Parr
 Plusnet Staff
mike360
Hi chris can you test our line please for some reason our speeds are slow but not for a month just today. thanks
Fixes: 162
@mike360
Testing your line isn't showing any issues.
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 2.0 Mbps
Estimated Line Length In Metres 716.3
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-2M Upstream, Error Protection Off
Time Stamp 2017-02-09T20:00:00
 Chris Parr
 Plusnet Staff
mike360
OK my speeds did return earlier on and i did a quiet line and my line is ok, iv done what you have asked. What does this mean "GEA service test completed and no fault found but unable to check for customer equipment connected to modem" thanks
Plusnet Staff
Plusnet Staff
Fixes: 117
It just means that the test has successfully run and it's not identified a fault with the service.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
mg2242
please can you test my line
Fixes: 162
We can test the line but it helps to know what issues you're having so we know what to test for?
 Chris Parr
 Plusnet Staff
