Upload Speed Increase
- Upload Speed Increase
Re: Upload Speed Increase
21-11-2017 9:34 AM
Mine went over this morning - noticed my router flashing orange for a minute or so and now get just short of 9MBPS upload.
21-11-2017 3:37 PM
21-11-2017 3:49 PM
Good result,
Not sure if you monitor your router stat's or to what level, do you know what our DS synch speed prior to the upgrade was ?
Have G.Inp paramerers been changed due to the re-synch ? (assuming you are on a Huawei FTTC cabinet)
21-11-2017 5:32 PM - edited 21-11-2017 5:55 PM
@tiffy wrote:
..., do you know what our DS synch speed prior to the upgrade was ?
Until today it was
10:50:21, 11 Nov. | ( 127.660000) PPPoE is up - Down Rate=39950Kbps, Up Rate=1999Kbps; SNR Margin Down=12.6dB, Up=20.7dB |
Since this morning, it's been
07:19:15, 21 Nov. | (851446.890000) PPPoE is up - Down Rate=39950Kbps, Up Rate=9999Kbps; SNR Margin Down=12.5dB, Up=12.9dB |
Yes, I am on a Hauwei cabinet but I don't know if my G.Inp has changed today. I use a Hub One router, and I don't think it reports that level of detail, does it?
(edit - added)
The ping time to the gateway is around 12ms and that hasn't changed for months, so I think G.Inp has been enabled all along and is still enabled. Does that make sense?
21-11-2017 7:06 PM
You are very lucky and have had a very painless profile change, you US parameters have not been effected at all.
I would think you are located very close to the FTTC cabinet and have virtually no noise issues as both your US & DS synch rates are on the top end of your contracted rates.
Yes, you are likely on US G.Inp as your FTTC cabinet is Huawei, as you have said, can't really tell much about the parameters from a PN Hub One, not a Broadcom chip set so very limited stat's monitoring capabilities.
I had quite a big impact on my US parameters as a result of the upgrade, lost over 3 Mbps US synch rate, however, my G.Inp profile was changes to retx low at the same time which increased the data throughput ratio so only experienced a small DS data speed loss.
As expected, I had a DLM re-synch 5 days after the upgrade when I re-gained some of my lost DS synch speed, however, went back on to G.Inp retx high profile which promptly negated that gain with it's associated lower data TP ratio !
Still appreciate the free US speed boost, believe my DS speed will eventually revert to previous rates when DLM works through it's various processes at it's own rate, certainly nothing PN can do about that.
I would not think your line should experience any further DLM interventions as a result of the upgrade as your DS SNRM has remained unchanged, obviously the US SNRM has changed with the new banding.
By the way, "RouterStats" has a dedicated monitoring program for the PN Hub One (BT HH5a) don't know if you have tried this, it's better than nothing and probably as good as it gets with respect to stat's monitoring on your router, I used this for the very short period of time I had the Hub One in service.
Enjoy your upgrade.
21-11-2017 8:07 PM
Yes, I'm lucky enough to be only about 200 yds from the street cabinet, so I get good signal. I guess my case is about as good as it gets.
I didn't know about the RouterStat program; thanks for the tip. I got it going quite easily on my HubOne, just needed to tweak the URL of the Helpdesk page.
Hope your connection settles down
22-11-2017 6:45 AM
22-11-2017 9:43 AM
@XYLC
See previous posts in this thread, DLM should eventually return your DS parameters / speed to original, my first DLM intervention post upgrade took 5 days, still more to come I would think as my DS SNRM is still high.
22-11-2017 9:45 AM
Apologies, previous post typo !
23-11-2017 8:04 AM
PN threw the switch for me last night early results...
23-11-2017 8:24 AM - edited 23-11-2017 8:27 AM
23-11-2017 9:44 AM
Now will plusnet give me same deal as a newbie in 3 months time 😂😂😂
23-11-2017 10:34 AM
Finally arrive here this morning about 07:30. Getting between 7.5 and 8 Mb up. have to wait and see what the DLM recons although my line is showing on DSLREPORTS an A for overall and A+ for quality. PIty the buffer bloat is not the same.
23-11-2017 11:25 PM
In the words of the Beatles song " I have to admit its getting better, better all the time"
26-11-2017 12:48 PM
We got the upload speed increase a couple of weeks ago - but testing it again this weekend, the upload is back to ~2Mbps. Download speed is same as before.
(Unsure exactly when the upload dropped - I work away, so wasn't around to test it)
Is it just going to be that the line can't cope with more than ~2Mbps up?
