Cannot Reconnect After Powercut (CHAP Authentication Failed)
- Cannot Reconnect After Powercut (CHAP Authenticati...
17-03-2018 5:19 PM - edited 17-03-2018 6:01 PM
Today I had to unplug the router (plusnet hub one) to rearrange wires and since then I cannot connect.
The router shows I have a DSL connection but every time I try to connect I get 'CHAP Authentication Failed'.
I have tried re-entering the login and pressing reset, which changes the login to setup@plusdsl.net (which connects successfully but I cannot go online). Changing the login back after this still does not work.
I have also tried a full reset of the router and changing the password online (and then on the router too).
Re: Cannot Reconnect After Powercut (CHAP Authentication Failed)
18-03-2018 12:53 PM
Called up support today and got it sorted.
Not sure what caused the issue though
