Upgraded to Fibre Extra- Connection drop outs
Trekkie
I upgraded to Fibre extra on 28th August, I have the BT Home Hub 6 A which was stable before the upgrade. Now it seems to have drop outs every night and starting in the day time as well.  Can someone advise as to what I should do, is this a fault , do I need to raise a ticket for? I attached logs from this morning.
2 REPLIES 2
Fixes: 420
Re: Upgraded to Fibre Extra- Connection drop outs
@Trekkie
Did you read this on your old thread:  https://community.plus.net/t5/My-Router/BT-Smart-Hub-6-rebooting-everyday-at-12am/m-p/1763126#M21211
Trekkie
Thanks Baldrick1 I will wait a week and monitor, it , hopefully it will settle down. Thanks for the advice.
