Upgraded to 80/20 no change in upload speed
- Upgraded to 80/20 no change in upload speed
20-08-2021 10:16 AM
It's been 2-3 weeks since my upgrade from 40/10 to 80/20 and while I have an increased download speed (albeit near the lower end) the upload speed has remained the same at 9 - 10 Mbps which is below my new estimate.
In lieu of carrying out full tests over the weekend (quiet line, BT speed test, test socket, LAN to router, router stats) I wonder if it's possible to do an initial check on my account to see if there's anything awry.
I've attached the results of the Broadband Availability Checker
Re: Upgraded to 80/20 no change in upload speed
20-08-2021 10:42 AM
Re the above, I have a static IP (purchased) if it's relevant.
20-08-2021 1:36 PM
@1066_1066 A static IP will have no effect on your sync speeds which are rather low for the estimates, the upload at 9.63Mbps is below the minimum impacted range figure. How are you connecting the router is it direct to the incoming master socket? Is it a filtered faceplate? You could try the test socket to see if that improves the speeds. Really need to see the router stats to see if they give any clues to why the speeds are low.
20-08-2021 1:58 PM - edited 20-08-2021 2:00 PM
Thank you@RealAleMadrid , router is currently connected via an extension so I'll connect to the test socket and do the necessary tests over the weekend and post back.
20-08-2021 2:07 PM
@1066_1066 you are never going to get the best speeds if using an extension socket. In the early days of FTTC openreach would come and fit a filtered master socket along with a modem.
Your line may already be banded, so speed testing may not give your expected results, plus the DSL checker does not update every day. So if you take a copy of the Help Desk tab, in the advanced then troubleshooting tab, where the router is now, and then in the test socket you should see differences in sync and attainable speeds.
20-08-2021 4:15 PM
Hi @1066_1066. Thanks a lot for reaching out and I'm sorry to hear about the issues you're having with your upload speed.
I've run some tests on the line this afternoon which have not picked up on any issues with the broadband service - other than the speed, though a disconnection on the line has been detected with the phone (PSTN) service. I've now raised this with Openreach and we're hoping to have it sorted by 24/08/2021.
You can both view and comment on the open fault Ticket here should you need to.
20-08-2021 4:44 PM
Thank you @adam945, for picking this up. Much appreciated.
21-08-2021 9:40 AM
No problem @1066_1066
Give us a shout if you have not heard back from our Technical Support Team by 26/08/2021 and we'll check out what's going on for you.
