Unlimited fibre extra current line speed 21Mb BT IP profile is 70.89 Mbps
- Re: Unlimited fibre extra current line speed 21Mb ...
06-03-2016 12:48 AM
Yesterday (Fri 4 March) https://portal.plus.net/my.html?action=data_transfer_speed showed current line speed as 21Mb, estimated line speed 69Mb, and it hasn't changed.
BT Wholesale speed test shows IP profile of 70.89 Mbps.
Should I expect the current line speed to update automatically, or does Plusnet need to give it a nudge?
Martin
Re: Unlimited fibre extra current line speed 21Mb BT IP profile is 70.89 Mbps
06-03-2016 2:38 PM
06-03-2016 3:38 PM
07-03-2016 12:53 PM
Thank you, Plusnet!
09-03-2016 3:03 AM
09-03-2016 4:33 AM
mav:quote
09-03-2016 4:59 AM
mav:quote
09-03-2016 6:09 AM
From what I understand and it is limited
There is no reason for it to take up to 8 days your bt profile is set correctly and PlusNet's current line speed is set correctly it should be just a case of going into your router and dropping the connection (IE disconnect and reconnect)...
And your line should pick up the new speed......
If you have a hud one router type this into you browser
http://192.168.1.254 then login with the details found on the back of the router unless you have changed them and then you will be able to disconnect and reconnect..... Hope this helps
09-03-2016 8:26 AM
09-03-2016 8:30 PM
The only way to check current line speed on bottom of my sig link.
10-03-2016 10:56 AM
If you have the new combined router/modem then stop doing that. Every time the DSL connection is broken you risk the DSLAM thinking there is a fault. Too many of those in too short a period of time and DLM will start to intervene by lowering your connection speed.
Quote from: Mick1173 Hi i have rebooted the Router several times since i set it up to no avail.
10-03-2016 11:04 AM
Quote from: goldenfibre This is why PN hide the current line speed from the member connection setting as it used to be there before but not anymore. Cos they probably don't want the customer to know what are the line speed. It's so wrong really.
Please stop the conspiracy theories.
I can see we sent you an update yesterday on this. The order for fibre hasn't completed and is due to do so on the 22nd March.
