URGENT HELP TL-WDR3600 Router low speeds
- Re: URGENT HELP TL-WDR3600 Router low speeds
- « Previous
- 1
- 2
- Next »
08-01-2015 8:17 PM
Someone on another forum suggested setting the network connection speed manually from "Auto" to 100Mbs full duplex on the WAN port and their speed doubled on theirs but I don't know enough about the router to talk you through that I'm afraid.
08-01-2015 8:20 PM
http://www.tp-link.com/en/support/download/?model=TL-WDR3600&version=V1
08-01-2015 8:28 PM
08-01-2015 8:32 PM
08-01-2015 8:42 PM
08-01-2015 8:53 PM
08-01-2015 8:59 PM
08-01-2015 9:52 PM
Adam1240, you are on FTTC and getting ADSL 2+ speeds.
Please run the BTw Performance test (DO NOT REBOOT ANYTHING, ignore the red preamble except make sure no other programs are using the Internet) and that you are using a wired connection, and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
Do a Copy and Paste of the results and post here (no need to grab an image).
Also check your Current Line speed (Login required) - and post the information BUT Don't post your phone number.
08-01-2015 10:26 PM
Current line speed:
40 Mb
I did that test thing, it gave me result then did the 3rd set Tap3 or something? then it closed, now saying no FTTC on this premises?
08-01-2015 10:38 PM
http://www.speedtest.net/my-result/4044403646
08-01-2015 11:17 PM
08-01-2015 11:42 PM
09-01-2015 8:28 AM
09-01-2015 9:21 AM
Quote from: DomS A Gigabit network card can have 6 modes, 10 / 100 / 1000Mb/s plus full duplex on the afore mentioned speeds (20/200/2000).
Slightly misleading, as full duplex is still 10/100/1000, but capable of simultaneous transmit and receive
Though, I suppose it's no different from describing routers as "N600" when it's actually "n300" on both 2.4 and 5GHz (are there any device that aggregate the two connections?).
09-01-2015 10:47 AM
The previous suggestions were definitely the main ones I'd have chosen, but I'd also have investigated the powerline devices.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
- « Previous
- 1
- 2
- Next »
