URGENT HELP TL-WDR3600 Router low speeds
- URGENT HELP TL-WDR3600 Router low speeds
08-01-2015 5:39 PM
Can someone who knows or own one of these routers tell me if they had this problem and how to fix it?
I'm using a Powerline Adapter, but also on Wifi next to router im getting same speeds, the plusnet provided one gave me over 35+ MB so something isin't right.
Used PPOE to assign everything.
Re: URGENT HELP TL-WDR3600 Router low speeds
08-01-2015 5:50 PM
08-01-2015 5:52 PM
08-01-2015 5:59 PM
Have you tried hooking your PC directly up to an Ethernet port on the router ? If you get a slow speed through that then you may have a connection issue. If you get a faster speed then you potentially have a wireless issue although getting the slower speed through a homeplug as well would tend to rule that out.
Is it just one machine you've tried the speed test on or do you have access (or can you borrow) another machine to rule that out ?
08-01-2015 6:03 PM
08-01-2015 6:55 PM
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
08-01-2015 7:02 PM
how important is it to try it..
08-01-2015 7:07 PM
If you get the same speeds then you need to report it as a fault. If you get better speeds you can then look at the potential issues with the router.
08-01-2015 7:12 PM
08-01-2015 7:15 PM
08-01-2015 7:17 PM
You would normally just set up the PPPoE connection on the routers WAN port then use NAT internally through the router. Only one device should be accessing the BT Modem through PPPoE and that is normally the router.
08-01-2015 7:24 PM
08-01-2015 7:26 PM
Have you tried swapping it back to the Plusnet Provided router yet ? This will be one of the first things the Customer Support may ask you to try before troubleshooting further.
08-01-2015 7:28 PM
08-01-2015 7:32 PM
