Traffic Management
- Re: Traffic Management
Traffic Management
23-07-2019 10:00 AM
I have just had an interesting conversation with another ISP, who stated the PlusNet employ traffic management, which they confirmed when I asked them to repeat it.
I at first was dubious, but bearing in mind that I had a previous ticket with PlusNet where despite syncing at 22Mbs, my speed-tests (direct connection) dropped at 18:00 to 23:59 , every evening.
Despite being reassured that the VLAN was ok, the back-haul was sufficient the situation persisted.
Numerous BT speed tests were performed, but after a lengthy call with PlusNet, poof, that day the throughput went up to 20Mbs as if by magic.
The speed tests have shown a reduction to 19Mbs over the last few weeks, sync speed 22Mbs, but not enough to warrant an engineer visit. I am informed there is no issue with the profile (though the BT test sometimes begs to differ)
This begs the question, has anyone else experienced what they would regard as traffic management?
PS please can I have a comprehensive GEA or whatever its called these days.
23-07-2019 11:12 AM
Assuming you're running your speed tests over a wired connection to exclude Wi-Fi I had a similar problem a few years back. For me It turned out to be a bottleneck at my exchange. Took a few Openreach visits & a while to get it straightened out at Plusnet's end but never had the same issue after that..
23-07-2019 11:20 AM - edited 23-07-2019 11:21 AM
Hi @dws1900, thanks for getting in touch. I can assure you that although we used to some time ago (traffic management as in streaming and gaming data taking priority over say browsing that is), there's currently no traffic management applied on your connections and the only way to get this applied if a customer required now would be to add the pro add-on.
There are a few things that can potentially at times cap the speed both on our and suppliers side given the set-up. If a customer has a static IP address then the throughput speeds could be subject to the workplace profile our side and is something we keep in mind when working on connections that have a static IP that are reporting speed issues. Alternatively, our supplier at times can incorrectly band speeds, for example a common banding we see is a provisioned 80Mbps connection being banded at 55Mbps. Again this is something we look out for when looking into speed issues.
Checking into your connection we are seeing 23.1Mbps download getting to the router with no signs of errors or issues shown on the graph below:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 23.1 Mbps |
Upstream Speed | 2.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Detected |
Estimated Line Length In Metres | 1513.8 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Regular Interference Observed on Week Days |
Service Impact | Retrains Observed |
Interference Duration Longest Occurrence | From12:45to13:00 |
Interference Location | Unknown |
Interference Observed In Days | 0 |
Home Wiring Problem | Not Detected |
Technology | VDSL |
Profile Name | 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2019-07-10T11:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 22.0 Mbps | 23.1 Mbps | 22.9 Mbps |
Up Stream Line Rate | 1.8 Mbps | 2.0 Mbps | 1.9 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 894.8 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-07-23T09:45:11Z | 2019-07-23T10:00:11Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Is it that you're testing your speeds on a wired or wireless connection when doing so? Also, are there any other devices or applications at the time of testing the speeds that could be using some bandwidth and explain the missing speed?
23-07-2019 11:35 AM
re
As stated
Re other devices, no.
Thanks for the GEA report, which is interesting as
1. Crosstalk appeared in Nov 2018 as OR added another 128 line capability on a cabinet that is too far away.
2.The street had a serious REIN in Sep 2018, I wonder if that has reappeared, I will talk to the owner of the property.
