TP-Link C3200 won't connect
FIXED- Subscribe to RSS Feed
- TP-Link C3200 won't connect
Re: TP-Link C3200 won't connect
30-04-2016 6:40 PM
@laralou - Well I think you should simply replace the gateway value that was / is there with 192.168.1.1 save the config, then reboot the PC or re-start the NIC.
30-04-2016 6:43 PM
Do I go to the lan pge first & do that like 'Spendlesstime' said or do I do it all on the dhcp page?
30-04-2016 6:57 PM
@laralou - Best to take @SpendLessTime's advice then configure as suggested.
30-04-2016 6:59 PM - edited 30-04-2016 7:04 PM
I'm not configuring anything until I know specifically what page to go to first what value to change etc. There is no point guessing what people want me to do. If you tell me I'll do it
But as it stands the post was vague do you want me to only go to the page he said
'On the TP-Link devices (c5 and C3200) the IP address for the router (LAN side) has to be set too.' & do what? Do I then go to the DHCP page?
I appreciate the help but I can't read minds here fellas.
30-04-2016 7:44 PM
I'm sorry I can't help you with the specific page as referred to by @SpendLessTime, maybe he can post an update, but I was suggesting that you carry out his suggestion then change the settings on the DHCP Server page.
Having said that from his post I see "On the C3200, click the advanced tab and then it is on the tab Network -> Lan as LAN IPv4". Once you have done this the do the DHCP and reboot the router, it may do it automagically anyway. Then reboot your PC or disable then re-enable your network card on your PC.
30-04-2016 8:04 PM
Hi
Been away shopping for tonight's tea which I'm preparing.
From the router page, click the "Advanced" Tab at the top of the page.
Then click on "Network" in the left column.
Then click on "Lan" in the same column.
Change the field called LAN IPv4 from 192.168.0.1 to 192.168.1.1 (assuming that was the value from the old working router)
Click on the "Save" button on the LAN tab.
Then click on the "DHCP Server" in the left column which is 2 below the LAN button.
Look at the fields "IP Address Pool".
Has it change to be "192.168.1.100" to "192.168.1.200"?
It not, change it to those values.
Look at the field "Default Gateway"
Has it changed to be "192.168.1.1" ?
It not, change it to that value.
Click "Save" on the tab just below the field "secondary DNS"
Now click on the "Reboot" button on the far top right of the webpage.
Once the router is rebooted, restart your PC to get an IP address in the new IP range of "192.168.1.100" to "192.168.1.200" from the router.
When the PC is rebooted, log onto the router and check the status. If the status is not connected, goto the Advanced tab, "system tools" and check the "system log" for messages.
30-04-2016 8:35 PM - edited 30-04-2016 9:14 PM
@laralou these are essentially the steps we went through earlier, but with different numbers. Hope it works though.
Another silly thing to confirm is that you are using the right username and password, so username is xyz@plusdsl.net where xyz is the username and password are the ones you use to login to the Plusnet portal
Again if this attempt also fails, plug your old router back in and can you send the PPP logs it creates when it connects, something is different at the PPP level and it is not obvious that changing the DHCP addressing will do anything to fix a PPP problem.
3Mb FTTC
30-04-2016 9:03 PM
@godsell4 you've put a comma between plusdsl and net
30-04-2016 9:15 PM
well spotted, looked like a speck of dust on my laptop screen, corrected that now.
3Mb FTTC
30-04-2016 10:04 PM
@Anonymous @godsell4
I've been looking at the log file that the OP posted in message number 58 in this file
And I have found this really old forum post from a Jelv1 at reply 26.
In both cases, the CHAP Challenge from Plusnet has a gateway name which looks wrong and when the router sends the CHAP response, the gateway is rejecting it and replies with an LCP EchoRep.
In the case of Jelv1's problem, the router is able to renegotiate successfully the LCP stage and gets another CHAP Challenge from Plusnet.
However, in the OP's case, the router and Plusnet can never agreed again during the LCP phase so it fails eventually.
The issue is the name Plusnet send in the CHAP Challenge stage (and some dodgy router code no doubt)
Thoughts please?
01-05-2016 8:18 AM
Well here is what the log looks like from a C5, you have to read from the botton upwards, most recent message or event is at the top:
Index Time Type Level Log Content 51 3rd day 10:33:03 PPP NOTICE PPPoE connected 50 3rd day 10:32:54 PPP INFO In pppd the httpd-id is 624, set link phase is 0x8 49 3rd day 10:32:54 PPP INFO send_phase 2196 pppd_phase = 0x8 48 3rd day 10:32:54 PPP INFO delete old gateway^M 47 3rd day 10:32:54 PPP INFO ipcpup : ipcp_wantoptions[0].default_route = 1^M 46 3rd day 10:32:54 PPP INFO rcvd [IPCP Ack addr=80.229.236.79 dns1=212.159.6.10 dns3=212.159.6.9] 45 3rd day 10:32:54 PPP INFO sent [IPCP Req addr=80.229.236.79 dns1=212.159.6.10 dns3=212.159.6.9] 44 3rd day 10:32:54 PPP INFO rcvd [IPCP Nak addr=80.229.236.79 dns1=212.159.6.10 dns3=212.159.6.9] 43 3rd day 10:32:54 PPP INFO sent [IPCP Ack addr=195.166.128.183] 42 3rd day 10:32:54 PPP INFO rcvd [IPCP Req addr=195.166.128.183] 41 3rd day 10:32:54 PPP INFO sent [IPCP Req addr=0.0.0.0 dns1=0.0.0.0 dns3=0.0.0.0] 40 3rd day 10:32:54 PPP INFO In pppd the httpd-id is 624, set link phase is 0x7 39 3rd day 10:32:54 PPP INFO send_phase 2196 pppd_phase = 0x7 38 3rd day 10:32:54 PPP INFO rcvd [CHAP Success ""] 37 3rd day 10:32:53 PPP INFO sent [CHAP Response (ccc78e1fc0c4efa22f425d4a91610ef1), name = "username@plusdsl.net"] 36 3rd day 10:32:53 PPP INFO rcvd [CHAP Challenge (492ba2248886435f5b70b53b2101519f), name = "PCL-AG02"] 35 3rd day 10:32:53 PPP INFO In pppd the httpd-id is 624, set link phase is 0x5 34 3rd day 10:32:53 PPP INFO send_phase 2196 pppd_phase = 0x5 33 3rd day 10:32:53 PPP INFO rcvd [LCP Ack mru=1480 magic=0xf3a980d] 32 3rd day 10:32:53 PPP INFO sent [LCP Ack mru=32725 auth=chap-MD5 magic=0xa8b7c58] 31 3rd day 10:32:53 PPP INFO sent [LCP Req mru=1480 magic=0xf3a980d] 30 3rd day 10:32:53 PPP INFO In pppd the httpd-id is 624, set link phase is 0x4 29 3rd day 10:32:53 PPP INFO send_phase 2196 pppd_phase = 0x4 28 3rd day 10:32:53 PPP WARNING LCP down 27 3rd day 10:32:53 PPP ERROR LCP down 26 3rd day 10:32:53 PPP INFO rcvd [LCP Req mru=32725 auth=chap-MD5 magic=0xa8b7c58] 25 3rd day 10:32:53 PPP INFO sent [CHAP Response (2497e0cfbf9636f8cbc5c2b5cf6769a2), name = "username@plusdsl.net"] 24 3rd day 10:32:53 PPP INFO rcvd [CHAP Challenge (d37b6409231083de9984cbaf8a11d3efe6a40b72c12ad92118843cb7a86f317cea95068da5896c3f8db76f18), name = "acc-aln1.cp"] 23 3rd day 10:32:53 PPP INFO In pppd the httpd-id is 624, set link phase is 0x5 22 3rd day 10:32:53 PPP INFO send_phase 2196 pppd_phase = 0x5 21 3rd day 10:32:53 PPP INFO rcvd [LCP Ack mru=1480 magic=0x58cde059] 20 3rd day 10:32:53 PPP INFO sent [LCP Ack mru=1492 auth=chap-MD5 magic=0x4eb686c3] 19 3rd day 10:32:53 PPP INFO rcvd [LCP Req mru=1492 auth=chap-MD5 magic=0x4eb686c3] 18 3rd day 10:32:53 PPP INFO sent [LCP Req mru=1480 magic=0x58cde059] 17 3rd day 10:32:53 PPP INFO In pppd the httpd-id is 624, set link phase is 0x4 16 3rd day 10:32:53 PPP INFO send_phase 2196 pppd_phase = 0x4 15 3rd day 10:32:53 PPP INFO rcvd [PADS sess-id(942)] 14 3rd day 10:32:53 PPP INFO sent [PADR Host-Uniq(0x000009cb)] 13 3rd day 10:32:53 PPP INFO rcvd [PADO AC-Name:acc-aln1.cp AC-MAC:10:e8:78:a7:e6:19] 12 3rd day 10:32:53 PPP INFO sent [PADI Host-Uniq(0x000009cb)] 11 3rd day 10:32:53 PPP INFO In pppd the httpd-id is 624, set link phase is 0x2 10 3rd day 10:32:53 PPP INFO send_phase 2196 pppd_phase = 0x2 9 3rd day 10:32:53 PPP NOTICE g_cmdBuf:pppd pppoe eth0.2 defaultroute unit 0 noaccomp nopcomp httpd-pid 624 user_len 20 passwd_len 6 special-flag 100 mru 1480 mtu 1480 usepeerdns 8 3rd day 10:32:53 PPP NOTICE Standard authentication. 7 3rd day 10:32:53 PPP NOTICE call pppoeFormatCmd 6 3rd day 10:32:51 PPP NOTICE call pppUserStart 5 3rd day 10:32:51 PPP NOTICE call pppoeCmdReqIPv4 4 3rd day 10:32:50 PPP NOTICE PPPoE start connecting... 3 3rd day 10:32:49 DHCP INFO DHCPS:Send OFFER with ip 192.168.1.102 2 3rd day 10:32:49 DHCP INFO DHCPS:Recv DISCOVER from 00:0F:B5:BB:46:BB 1 3rd day 10:32:46 local_root=%s%s
I am not sure at all this is the same issue raised by @jelv all those years ago.
3Mb FTTC
01-05-2016 8:28 AM
@godsell4, @SpendLessTime - Well we do not know as yet if the previous changes have worked, so getting that information from @laralou would be good.
01-05-2016 8:41 AM - edited 01-05-2016 8:41 AM
@SpendLessTime @Anonymous @godsell4
I followed the instructions from post 96 to the letter. In addition, when it didn't work I tried uninstalling the network adapters then rebooted windows (again) & let it rebuild them from scratch
01-05-2016 8:49 AM
@Anonymous @SpendLessTime
Here are the logs from the working router (old router) as requested by @godsell4
01-05-2016 9:15 AM
@laralou, @godsell4, @SpendLessTime - Am I missing something here? In the ...1-4.jpg log view the 3rd line from the end says that the PPPoE is connected! Is this not what we have been trying to achieve?
What are you doing to physically check the your PC in on the internet? Remember on Windows there can be a bit of a delay before the network icon in the status bar at the bottom of the screen says that the Internet is available. Also you have have another device you can use to check availability?
