Sudden Drop In Speed
jamesanstee
Re: Sudden Drop In Speed
Just to update on the 3db profile trial  line has been quite stable for 26 days which is the longest so far that my line has stayed connected without any re-syncs .
jamesanstee
@bobpullen Has there been any further developments in regards to the 3db trial , So far my line has remained stable for 49 days while on the 3db profile so results do look quite promising .
jamesanstee
After 2 months of my line being stable on the 3db profile the line has had a resync and speed has dropped to 57Mbps IP profile was at 71Mbps for 2 months now has dropped to 57 have done the usual checks quiet line test incase of any noise on the line but cannot hear anything but noise margin has gone back up to 6db @bobpullen @Anoush as to why its reverted back considering the line had been stable for 2 months.
Fixes: 1,601
I am sorry for the delay in my response.
I've recently joined the social media team, and as such I've had to create a new forum account so I don't look at the notifications on my old account very often.
It looks like you're back down to 3db... Grin
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 71.8 Mbps
Upstream Speed 16.5 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 501.4
Upstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
jamesanstee
The line length looks a bit odd to me as its showing that the line length has increased comparing to a previous test. line test.JPG
RealAleMadrid
Aspiring Hero
Fixes: 59
It's only an estimated line length, not an actual measurement and its only changed by a few metres so nothing to worry about.Smiley
