Static ip addon not working.
wiganfcfan07
Hi, currently using a billion 8800nl router. (Around 1 hour ago) added the addon today, but cannot get this static ip i have been given to work. It just says you need to restart.
Any help would be great, thanks.
7 REPLIES 7
Chris
Legend
Fixes: 169
Re: Static ip addon not working.
You shouldn't need to make any changes to your router at all. Your current connection is showing as using the static IP assigned to your account too.
wiganfcfan07
I cannot get it to work at all. I have used this feature before with be(My old isp). Just tried resetting router and re-configuring, but still it doesn't work.
jelv
Fixes: 10
DO NOT reconfigure your router. It should still be set to get the IP when you connect. What will happen is that every time you connect you will be assigned the same IP.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Chris
Legend
Fixes: 169
What can't you get to work? You are connecting on your static IP and have done the last 3 connections now.
You do not need to set your router to use a static IP, leave it on dynamically assigned.
If you want to see if you are connecting on the same IP, visit whatismyip.com
wiganfcfan07
Ok thanks Chris. Is this a monthly fee or one off? (My ip checker wasn't updating).
Fixes: 396
It's a one off charge.
wiganfcfan07
Ok thanks for your help.
