I'm paying £19.99 for a package that cost £14.99 ???
lxkid
So I had a phone from plusnet next , to see if I'm getting the right deal, I'm sure when I joined plusnet I made sure I was getting the top speeds possible for the prices being paid by myself, so I cut the phone call short so I could investigate , so not only am I getting low download speeds also upload .
So has everything changed with out my knowledge ?? The package and prices I should of been on ?
19 REPLIES 19
Fixes: 62
Re: I'm paying £19.99 for a package that cost £14.99 ???
Perhaps your introductory discount has finished which may be why you got the phone call
NorthEasterner
You may be on the Unlimited Fibre Extra package (up to 76mb) hence why you're paying £19.99
The £14.99 is the Unlimited Fibre package (up to 38mb).
Plusnet are not allowed to change your package without your consent.
NE
Ex Plusnet Fibre customer. TalkTalk Fibre Customer using a TalkTalk WiFi Hub. If you wish to say thanks, please click the thumbs up :thumbsup:
Fixes: 632
The old unlimited fibre package is up to 80, so could be naming confusion.
lxkid
If I went back 18 months I'm sure the best fibre deal then possible was 79 down and 19 up for  £19.99 which I would of taken , I might be mistaken tho.
So today I'm get 38 down and 1.9 up .... But for the last year my upload has been between 15 &19 and down between 22-49 so something has changed.
Confused.
Fixes: 167
Your package is based on the 80/20 wholesale product, not the 40/2 one.
What speeds are you seeing when you do a speedtest?
 Chris Parr
 Plusnet Staff
lxkid
What speeds should I have been getting 18 months ago when I took this deal out ? That's my question , because the person told me today that I was capped at 38 down and 1.9 up and that's not what I signed up to 18 months ago at £19.99 plus line rental
Fixes: 167
The person on the phone was wrong. Your speeds/account have not changed since then.
The package you are on is called Plusnet Unlimited Fibre, this is the equivalent to our current Unlimited Fibre Extra package and offers the same speeds, both are £19.99.
The confusion is that since then we've had a new package call Unlimited Fibre (note that it's doesn't have the word Plusnet at the start) and this is £14.99 but offers the lower speeds.
 Chris Parr
 Plusnet Staff
lxkid
That's why I was confused , I may have pick the call up all wrong , the person was polite and me also , just when ended the call my brain went into over drive as to how this all might of happened with out me knowing.
lxkid
Chris can you update me with my potential speeds up and down that I should be getting ?? Thanks
Fixes: 167
Your speed estimates can be found here: http://www.dslchecker.bt.com/
 Chris Parr
 Plusnet Staff
lxkid
Would that indicate the current deal I'm on ? my potential speeds as of now with what I'm paying for?
Fixes: 62
Quick check - what are the IP profiles reported here (ignore upload speed test result as that will be wrong) http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
Fixes: 167
No, speeds are not the best way to indicate the deal you're on as they can change/fluctuate. As you haven't changed package, you are still on exactly the same one you were on previously.
 Chris Parr
 Plusnet Staff
lxkid
Ok thank you to everyone who has replied, much appriciated.
