Speed below minimum
- Speed below minimum
Speed below minimum
05-03-2020 10:13 PM - edited 05-03-2020 10:14 PM
- Product: Unlimited Fibre Extra
- Estimated Download Range: 49 - 69Mbps
- Estimated Upload Range: 13 - 18Mbps
- Minimum Guaranteed Speed: 44.4Mbps
- Current Line Speed (Download): 39.2Mbps
As you can see, the speed is below the minimum I should be getting. I'm into my 4th week with Plusnet and all throughout the first 10 days I was getting around 46-48Mbps download and 15-16Mbps upload. All tests connected by ethernet. Now it's this:
BT Wholesale test
Download Speed (Mbps): 36.49
Upload Speed (Mbps) : 11.46
Ping Latency (ms): 30
Speedtest.net
Re: Speed below minimum
08-03-2020 1:59 PM
This below is from the BTW Performance Test. As I mentioned in the previous post, I was getting around 46-48Mbps download when I first joined.
1. Downstream Test: -provides background information.
Download Speed | |
37.04 Mbps |
0 Mbps | 40.02 Mbps Max Achievable Speed |
Download speedachieved during the test was - 37.04 Mbps For your connection, the acceptable range of speedsis 40 Mbps-40.02 Mbps . Additional Information: IP Profile for your line is - 40.02 Mbps |
Upload Speed | |
9.78 Mbps |
0 Mbps | 20 Mbps Max Achievable Speed |
Upload speed achieved during the test was - 9.78Mbps Additional Information: Upstream Rate IP profile on your line is - 20 Mbps |
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
12-03-2020 4:09 PM
Good afternoon!
Apologies for the late response times from ourselves recently and also sorry to hear about the issues you're experiencing.
It seems like this could be a Throughput based issue from the hardware or maybe a profile speed error from the DLM within the local exchange.
If you could kindly send me a private message with your account username I'd be happy to look into this inquiry further for you.
Kind regards,
JARVIS
