Speed and stability issues
- Speed and stability issues
16-09-2015 10:25 PM
Apologies if I am not supposed to post this here, but had problems getting through in any other way and after a lot of trying finally managed to find this forum. My issue is that I am appear to be losing my service completely once or twice a week and otherwise having issues daily, in terms of Netflix or Youtube freezing or dropping off on both my Blu-ray and on my phone and frequent lag issues in online gaming, which is leaving me wanting to see if another provider can provide a better connection. On another note, I was disappointed to find no apparent option to e-mail customer service with this. BT wholesale test as below. First test failed, second and third test almost identical results:
1. Best Effort Test:
Download Speed : 29.65 Mbps
2. Upstream Test:
Upload Speed : 2.8 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information
2. Upstream Test:
Message 1 of 8
(1,046 Views)
7 REPLIES 7
Re: Speed and stability issues
16-09-2015 10:27 PM
Should have said - happy for this to be responded by customer service in next day or two - no urgency as had this issue for a while but need it resolving in the medium term. Also, PlusNet line speed as follows: Estimated line speed:There's no speed estimate currently held on your account. Current line speed:31.8 Mb. EDIT - I have previously had customer service find a 'stale session', which was causing issues a few months ago, so they reset my connection (or something similar).
Message 2 of 8
(566 Views)
20-09-2015 8:57 AM
Hi, still hoping to hear from plusnet if possible. Thanks.
Message 3 of 8
(566 Views)
21-09-2015 11:40 AM
Message 4 of 8
(566 Views)
25-09-2015 5:54 PM
Thanks for looking at this for me. I've now replaced my Cisco USB wireless adapter with a Gigabyte wireless card, so hoping things will get better, so will only contact again if not. There have been a few drop-offs from your side, including most of a day a few weeks ago but I wonder whether the more regular issues were my adapter then.
Message 5 of 8
(566 Views)
26-09-2015 9:27 AM
Further to this, would it be possible to do a line check, as I don't seem to have a speed estimate (though 30MB isn't bad)? I was also wondering whether the upload speed is what I should be expecting for fibre, this being between 2.5-5MB depending on when I do my test.
Message 6 of 8
(566 Views)
28-09-2015 6:32 AM
No internet again this morning (on 4g on phone now). Wonder if connection needs resetting your end same as last call I made when you said I had a stale session or something one that.
Message 7 of 8
(566 Views)
28-09-2015 2:21 PM
Message 8 of 8
(566 Views)
