Speed Drop
- Full Fibre
- Speed Drop
Speed Drop
02-04-2021 10:27 PM - edited 02-04-2021 10:45 PM
When I signed up my guaranteed speed was 34. I have for the past year + consistently had speed test results of 35.3+ / 8.8+.
Over the past few weeks speed has dropped off and now am getting speed tests of 30 / 5. Router log shows a dropping off of connection rates.
02:31:29, 31 Mar. Down Rate=32620Kbps, Up Rate=5691Kbps; SNR Margin Down=6.1dB, Up=6.0dB
00:31:34, 24 Mar. Down Rate=34612Kbps, Up Rate=5736Kbps; SNR Margin Down=6.1dB, Up=5.9dB
02:52:48, 16 Mar. Down Rate=36629Kbps, Up Rate=9558Kbps; SNR Margin Down=5.1dB, Up=6.0dB
00:54:13, 15 Mar. Down Rate=36691Kbps, Up Rate=8937Kbps; SNR Margin Down=5.1dB, Up=6.0dB
01:14:04, 12 Mar. Down Rate=36626Kbps, Up Rate=9494Kbps; SNR Margin Down=5.1dB, Up=5.7dB
22:33:03, 21 Feb. Down Rate=38171Kbps, Up Rate=9464Kbps; SNR Margin Down=4.6dB, Up=5.9dB
02:05:14, 14 Feb. Down Rate=38171Kbps, Up Rate=9278Kbps; SNR Margin Down=4.6dB, Up=6.0dB
20:45:21, 05 Feb. Down Rate=37069Kbps, Up Rate=9599Kbps; SNR Margin Down=5.1dB, Up=5.9dB
02:22:11, 12 Jan. Down Rate=38171Kbps, Up Rate=9987Kbps; SNR Margin Down=4.8dB, Up=5.1dB
00:37:27, 07 Jan. Down Rate=37395Kbps, Up Rate=9632Kbps; SNR Margin Down=5.2dB, Up=6.0dB
6. Data rate: | 5680 / 32995 |
7. Maximum data rate: | 5683 / 34527 |
8. Noise margin: | 5.8 / 6.0 |
9. Line attenuation: | 27.3 / 16.0 |
10. Signal attenuation: | 28.7 / 15.8 |
Could someone have a look
TIA
Re: Speed Drop
09-04-2021 10:31 AM - edited 09-04-2021 10:36 AM
Stats dropped again
00:14:27, 08 Apr. Down Rate=31008Kbps, Up Rate=5677Kbps; SNR Margin Down=6.8dB, Up=6.0dBB
6. Data rate: | 5677 / 31008 |
7. Maximum data rate: | 5613 / 32618 |
8. Noise margin: | 5.6 / 6.7 |
9. Line attenuation: | 27.1 / 15.9 |
10. Signal attenuation: | 29.1 / 15.9 |
So something is going on with my line
