Speed Drop
FIXED- Subscribe to RSS Feed
- Speed Drop
07-10-2017 4:11 PM
Used to get 67mb no problem, seem to have dropped to 50 according to BT WS only recent change was going for a Static IP address.
Was always pretty consistent at 67.
Fixed! Go to the fix.
Re: Speed Drop
08-10-2017 8:54 AM
Bloody useless 17mb drop, can't raise a fault as its 50mb unfortunately that's the problem with not going direct to BT.
300mb virgin for a few pound more seems the way forward.
Re: Speed Drop
10-10-2017 1:06 PM
Re: Speed Drop
10-10-2017 6:44 PM
Hi Matthew
Doesn't look any different to me. still around the 50mb down mark.
Re: Speed Drop
11-10-2017 4:11 PM
Hi there.
Your router is in sync as below:
Sync Status | In Sync |
Downstream Speed | 70.1 Mbps |
Upstream Speed | 20.0 Mbps |
Can you run a BT speedtest for me please at http://www.speedtest.btwholesale.com using a wired connection? Once you have the result, please complete the further diagnostics. This will store the result on the supplier system.
Re: Speed Drop
11-10-2017 7:58 PM
Hi
Done that
file attached with results, still the same. Although Upload speed looks to have got worse.
12-10-2017 11:33 AM
Re: Speed Drop
12-10-2017 1:53 PM
Many Thanks
Re: Speed Drop
12-10-2017 3:51 PM
