Speed Drop
ctaylor
Speed Drop
Used to get 67mb no problem, seem to have dropped to 50 according to BT WS only recent change was going for a Static IP address.
Was always pretty consistent at 67.
8 REPLIES 8
ctaylor
Re: Speed Drop
Bloody useless 17mb drop, can't raise a fault as its 50mb unfortunately that's the problem with not going direct to BT.
300mb virgin for a few pound more seems the way forward.
MatthewWheeler
Fixes: 479
Re: Speed Drop
Sorry to hear you've been having issues.
From what we can see your sync speeds have increased back to normal.
Are you still seeing issues?
 Matthew Wheeler
ctaylor
Re: Speed Drop
Hi Matthew
Doesn't look any different to me. still around the 50mb down mark.
Fixes: 1,600
Re: Speed Drop
Hi there.
Your router is in sync as below:
Sync Status In Sync
Downstream Speed 70.1 Mbps
Upstream Speed 20.0 Mbps
Can you run a BT speedtest for me please at http://www.speedtest.btwholesale.com using a wired connection? Once you have the result, please complete the further diagnostics. This will store the result on the supplier system.
ctaylor
Re: Speed Drop
Hi
Done that
file attached with results,  still the same. Although Upload speed looks to have got worse.
Fixes: 1,600
Re: Speed Drop
I've re-set the connection profile on our side
Can you reboot your router and retest your speed please?
ctaylor
Re: Speed Drop
Many Thanks
Fixes: 1,600
Re: Speed Drop
No problems.
All sorted?
