Speed Drop
- Speed Drop
Speed Drop
08-04-2015 2:05 PM
I've noticed that my speed has dropped a bit recently and my ping has gone quite high as well. I normally get close to the full download speed. Can someone take a look at it for me please?
Message 1 of 2
(394 Views)
1 REPLY 1
Re: Speed Drop
08-04-2015 2:32 PM
There isn't anything too wrong I can see from here
Your current profile is "0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Interleaving On" so as a result of the interleaving being enabled your pings will be a little higher but not by much.
The sync speed has dropped a little however this isn't down to Dynamic Line Management as your profile is good. We'll struggle to raise this further as your sync hasn't dropped enough for our suppliers to class it as a fault.
Message 2 of 2
(217 Views)
