Slow download speed on fibre
- Slow download speed on fibre
03-03-2016 11:32 PM
Just been upgraded to fibre from adsl, my wan speed is reported as 39,999 kbps down, 1998 kbps up. When doing a speed test I am only getting around 5 Mbps down, up is fine at Mbps.
Any ideas, my guess is plusnet haven't changed my speed cap.
Message 1 of 2
(520 Views)
1 REPLY 1
Re: Slow download speed on fibre
04-03-2016 1:05 AM
Hello there. Aye, it does sound like we need to manually update your connection profile to the fibre speed. I'd recommend contacting us by webchat tomorrow morning. You'll then need to disconnect and reconnect your PPP session (or reboot your router) to accept the new change in speed.
Hope this helps
Hope this helps
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Message 2 of 2
(280 Views)
