Separate my Fonera from my network
- Re: Separate my Fonera from my network
05-02-2015 7:47 PM
Hi
Wondering if any experts on here could help...
So I have a Fonera connected to my BT hub 5. Fonera gives me free access to Fon hotspots - but I have to provide access to others, fair enough.
However I recently purchased a Seagate Central and this shows up via the public connection - which is quite concerning for me.
Is there a way of the Seagate not appearing via the Fon router? Perhaps changing IP range etc...
NE
NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 1 of 9
(1,422 Views)
8 REPLIES 8
05-02-2015 8:07 PM
DMZ ?
Message 2 of 9
(1,027 Views)
05-02-2015 8:34 PM
Where would I apply this?
To the fonera or to the hub 5?
Message 3 of 9
(1,027 Views)
05-02-2015 9:16 PM
I suggest you do some research on DMZ before you decide if it is suitable but it could well be an option for you. You set it up on the router and on many routers you can isolate the DMZ device from other parts of your network.
Worth doing a little research before adding it.
Message 4 of 9
(1,027 Views)
05-02-2015 9:21 PM
Surely the Fonera WiFi should be on a different subnet to the HH5 LAN, and be offering a separate DHCP range, so the two networks shouldn't see each other ?
Personally I wouldn't try the DMZ thing, as different routers implement DMZ in a variety of ways, and many are not safe for what you are trying to do, so I wouldn't risk it without a lot of testing.
Message 5 of 9
(1,027 Views)
05-02-2015 9:46 PM
I tried the DMZ and messed it up.
Turned it back off and still messed up.
My computer can no longer see the Seagate Central - even via HH5.
Arrghh!! I've tried restarting seagate but no luck - will restart hub and give seagate a new IP address.
NE
NE
Message 6 of 9
(1,027 Views)
05-02-2015 10:09 PM
All fixed up by re-assigning the IP address and using Seagate discovery tool.
I've realised I've been looking on the private Fonera SSID and not the public fonera SSID.
Public doesn't show up the NAS so all is secure.
Regards
NE
Regards
NE
Message 7 of 9
(1,027 Views)
05-02-2015 10:24 PM
Message 8 of 9
(1,027 Views)
05-02-2015 10:29 PM
I was stuck deciding between Seagate Central and WD MyCloud.
I went for Seagate as you can access it remotely from a web browser, where with WD you have to download plug ins and access via the windows explorer - however work computer doesn't allow downloads and WD2GO.com (remote access) is blocked. Leaving Seagate the option, which works fantastically
NE
NE
Message 9 of 9
(1,027 Views)
