Sagem 2704n daily reset
- Re: Sagem 2704n daily reset
- « Previous
- 1
- 2
- Next »
30-07-2015 5:49 PM
30-07-2015 5:54 PM
30-07-2015 7:50 PM
Well done if this proves to be the issue. There is no harm in naming the other ISP using the 2704n with their own firmware - it'll save us doing the searching
Fingers crossed then.
30-07-2015 8:15 PM
Thread on the Avast forum (ignore the unhelpful person - you'll know who it is lol) - also mentions the other ISP in that thread:
https://forum.avast.com/index.php?topic=161465.0
30-07-2015 8:24 PM
30-07-2015 8:34 PM
Ref the router model - I was browsing during my lunch at work so wasn't at home to check the model. I just saw Sagemcom 2*04n and made an assumption. Glad I did now though.
30-07-2015 11:54 PM
Is it problem solved do you think, Sunbite?
31-07-2015 4:51 AM
Perhaps a thread titled Avast issue might get the attention so it can be 'proved'? I do expect more to post as more of these routers are rolled out though. Apparently you can force the reboot by performing a network scan in Avast although I couldn't find the option at all - must be buried somewhere.
(1 day, 9 hours up time and counting by the way)
31-07-2015 8:48 AM
@Anotherone - Sunbite was right, I am currently using a TP-Link 9980 which has been solid since I bought it on Monday, even if Avast was the issue I am going to stick with the TP link due to dual band and it replacing the BT Openreach modem too. I will get round to testing my new replacement PN router but it will need to be the Bank Holiday week in August as that is my next full week at home due to working away.
This is a list of when all my drops have been since I first reported it on 8th July
8th - None
9th - None
10th - 2100
11th - Fit new PN router
12th - 1100
13th - 1830
14th - 1830
15th - None
16th - None
17th - 1900
18th - 1900, 2000
19th - 1910
20th - 1945, 2200
21st - 2000 then BT home hub 3 fitted
22nd - None
23rd - None
24th - 0030, 0330
25th - None
26th - None
27th - Fit TP Link 9980
28th Onwards - None
It does seem very similar to the problem Sunbite is having, Weird thing is the 2 drops after fitting the new router was when my other half was Skyping me, the 2 nights after no drops and we skype the same time every night, once I get chance to test it I will dig this thread out and update you.
Thanks all for the help
01-08-2015 6:07 AM
01-08-2015 11:58 AM
01-08-2015 12:53 PM
01-08-2015 12:58 PM
01-08-2015 1:51 PM
06-08-2015 1:23 PM
- « Previous
- 1
- 2
- Next »
